| 0004293 | Draft | Bug | public | 2020-03-23 07:50 | 2020-11-13 10:00 |
| Reporter | Lukas1 | Assigned To | yorik | ||
| OS | Linux | ||||
| Summary | 0004293: Vertical dimensions can't be created in XZ and YZ working plane | ||||
| Description | In the Draft workbench, vertical dimensions (using the Dimension tool with the Shift key) can't be created in XZ and YZ working plane, only in XY (top) plane. But horizontal dimensions work in all three planes. In XZ and YZ planes, vertical dimension disappears during its creation with the Shift key, and the result is a weird dimension connected to the 3D origin. So for example, I can't create a parametric vertical dimension of a slanted roof in the Arch workbench. I know about the principle "clicking Shift while the pointer is close or far from the first point", but it helps only in the XY plane. | ||||
| Steps To Reproduce | Switch to the Draft workbench, Utilities -> SelectPlane -> Front (XZ), View -> Standard views -> Front, select the Dimension tool, pick the first point anywhere, pick the second point of an imaginary slanted line, hold the Shift key and move the mouse pointer and try to create a vertical dimension of the slanted line. You can create only a horizontal dimension. Tested in the last FreeCAD 0.18.4 and 0.19 (20209). | ||||
| FreeCAD Information | OS: Linux Mint 19.3 (X-Cinnamon/cinnamon) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20209 (Git) AppImage Build type: Release Branch: master Hash: 5fc4a26a00390e91cbf91848b766b68ad87e5917 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
@Lukas1 : please familiarize yourself with our reporting guidelines and open a new topic on our forum first. Thx |
OK, thank you for the information, I will do it. |
Link to the forum |
FreeCAD: master 2b252445 2020-11-10 16:32:29 marioalexis Committer: yorik Details Diff |
Draft: Fixes 0004293: Vertical dimensions can't be created in XZ and YZ working plane |
Affected Issues 0004293 |
| mod - src/Mod/Draft/draftguitools/gui_dimensions.py | Diff File | ||
| mod - src/Mod/Draft/draftviewproviders/view_dimension.py | Diff File | ||
| 2020-03-23 07:50 | Lukas1 | New Issue | |
| 2020-03-23 14:32 | openBrain | Status | new => feedback |
| 2020-03-23 14:32 | openBrain | Note Added: 0014269 | |
| 2020-03-23 16:33 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-03-23 18:03 | Lukas1 | Note Added: 0014272 | |
| 2020-03-23 18:03 | Lukas1 | Status | feedback => new |
| 2020-03-25 17:24 | Lukas1 | Note Added: 0014291 | |
| 2020-03-26 10:28 | openBrain | Tag Detached: #post-to-forum | |
| 2020-03-26 10:28 | openBrain | Tag Attached: #pending-forum | |
| 2020-11-13 10:00 | yorik | Changeset attached | => FreeCAD master 2b252445 |
| 2020-11-13 10:00 | yorik | Note Added: 0014980 | |
| 2020-11-13 10:00 | yorik | Assigned To | => yorik |
| 2020-11-13 10:00 | yorik | Status | new => closed |
| 2020-11-13 10:00 | yorik | Resolution | open => fixed |
