| 0004317 | Arch | Bug | public | 2020-04-18 23:29 | 2021-02-06 06:28 |
| Reporter | azure | Assigned To | |||
| Summary | 0004317: Draft grid visible through an arch wall | ||||
| Description | See the attached screenshot wallbug.png. When looking at an arch wall from the top, the top of the wall appears "open" and you can see the draft grid through it. The problem seems to occur only if grid spacing is below 5mm. The smaller the spacing is, the larger area of the grid can be seen through the wall. If spacing is 5mm or larger, as in the screenshot wallbug_grid_50mm.png, the wall looks normal to me. If I turn the grid off, a black area appears on top of the wall as seen in the screenshot wallbug_grid_off.png | ||||
| Steps To Reproduce | - Use FreeCAD version from git shown in the section FreeCAD information. - Ensure the grid settings are "factory default". - Select Arch workbench. - Load the attached wallbug.FCStd file. - Make the grid visible (for me the grid is not always visible at first even though I believe it is "on" - I have to turn if off first and then back on). - Try changing the grid spacing and turning the grid off. | ||||
| FreeCAD Information | OS: Ubuntu 19.10 (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20634 (Git) Build type: Debug Branch: master Hash: ba34cc6a96c15d64224e8f0c8b5da874f1e03a07 Python version: 3.7.5 Qt version: 5.12.4 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
|  | @azure : when encountering issue with FreeCAD, please process according our reporting guidelines by first opening a topic in our forum. Here looks like a graphical issue. Does the problem vanish if you select 'Fit all' view ? |
|  | @azure please follow-up by posting a thread to the forum and posting the URL here. |
|  | @azure ping |
|  | I occasionally dive in to see if I can help with a bug/issue. I've looked at the sample file for this bug: the "Walltrace" is for a wall 50mm long, 3m high and 200mm thick - and I can't reproduce the 'error'. I wouldn't expect a reasonable interpretation. |
|  | Thanks @mikeprice99. Appreciate any help triaging that you'd offer :) I'll open a thread on the forum for this since OP ( @azure ) hasn't responded. Edit: forum thread: https://forum.freecadweb.org/viewtopic.php?f=23&t=50121 |
|  | This ticket has been migrated to GitHub as issue 6048. |
| 2020-04-18 23:29 | azure | New Issue | |
| 2020-04-18 23:29 | azure | File Added: wallbug.png | |
| 2020-04-18 23:29 | azure | File Added: wallbug.FCStd | |
| 2020-04-18 23:29 | azure | File Added: wallbug_grid_50mm.png | |
| 2020-04-18 23:29 | azure | File Added: wallbug_grid_off.png | |
| 2020-04-19 09:45 | openBrain | Tag Attached: #post-to-forum | |
| 2020-04-19 09:46 | openBrain | Status | new => feedback |
| 2020-04-19 09:46 | openBrain | Note Added: 0014359 | |
| 2020-04-25 14:04 | Kunda1 | Note Added: 0014377 | |
| 2020-06-07 14:23 | Kunda1 | Note Added: 0014500 | |
| 2020-07-22 19:26 | mikeprice99 | Note Added: 0014678 | |
| 2020-09-10 14:54 | Kunda1 | Note Added: 0014733 | |
| 2020-09-10 14:55 | Kunda1 | Note Edited: 0014733 | |
| 2020-09-10 14:55 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-09-10 14:55 | Kunda1 | Tag Attached: #pending-forum | |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
