| 0004349 | FreeCAD | Bug | public | 2020-05-23 10:44 | 2020-10-10 12:15 |
| Reporter | doronbehar | Assigned To | |||
| Summary | 0004349: Can't build with opencascade 7.4.0 (downstream NixOS repo trying to build v0.18) | ||||
| Description | Hi, On NixOS, we'd like to update opencascade (from https://www.opencascade.org/ ) to version 7.4.0 but we encounter a regression for the build of freecad with this update for opencascade. The build errors are as follows:
Feel free to close this if this error no longer appears in the 0.19 branch. | ||||
| Steps To Reproduce | Well you have to install Nix and all that so I wouldn't expect you to actually do that, but for reference, the PR for updating opencascade is here: https://github.com/NixOS/nixpkgs/pull/70668 | ||||
| Tags | downstream, linux, OCC Bug, packaging | ||||
| FreeCAD Information | It's a build error so I don't have this info. | ||||
@doronbehar thanks for posting, glad to see there are FreeCAD users on NixOS Heads up:We may not backport a fix like this to v0.18 (per the large yellow banner at the top of this page) Our attention is strictly on getting the postponed v0.19 release out ASAP. You are welcome to post this ticket to the forum (per our guidelines). Also we are currently patching our sourcecode to support the upcoming OCCT 7.5 which is currently in beta. |
Looks like downstream decided to package v0.19 dev for now. Thanks for bearing with is. Reference downstream ticket https://github.com/NixOS/nixpkgs/pull/70668 has been closed. PR: https://github.com/NixOS/nixpkgs/pull/98845 |
| 2020-05-23 10:44 | doronbehar | New Issue | |
| 2020-10-10 12:08 | Kunda1 | Note Added: 0014814 | |
| 2020-10-10 12:08 | Kunda1 | Tag Attached: OCC Bug | |
| 2020-10-10 12:08 | Kunda1 | Tag Attached: packaging | |
| 2020-10-10 12:10 | Kunda1 | Severity | block => minor |
| 2020-10-10 12:10 | Kunda1 | Status | new => feedback |
| 2020-10-10 12:10 | Kunda1 | Summary | Can't build with opencascade 7.4.0 => Can't build with opencascade 7.4.0 (downstream NixOS repo trying to build v0.18) |
| 2020-10-10 12:10 | Kunda1 | Tag Attached: linux | |
| 2020-10-10 12:11 | Kunda1 | Tag Attached: downstream | |
| 2020-10-10 12:15 | Kunda1 | Note Added: 0014815 | |
| 2020-10-10 12:15 | Kunda1 | Status | feedback => closed |
| 2020-10-10 12:15 | Kunda1 | Resolution | open => no change required |
