| 0004377 | TechDraw | Bug | public | 2020-06-18 12:08 | 2020-06-26 17:15 |
| Reporter | Retus | Assigned To | |||
| Platform | PC | OS | Windows | OS Version | 10 |
| Summary | 0004377: To Measure Problem with Tech Draw | ||||
| Description | The center lines (vertical and horizontal, crosshairs) are not displayed for circles. I should be able to choose the center of the circle to measure. The warning also comes when loading the FreeCAD 0.19: C:/:/dd/icons/LinearDimension.svg | ||||
| Tags | 0.19 | ||||
| has duplicate | 0004376 | closed | wandererfan | Problem bei Vermassen in Tech Draw |
go to technical draw first before setting up goto <Edit><Preferences><TechDrow><Annotation> Set X -Print Center Marks- go back to TechDraw Select The view In Property-View-Decoration- Set Arc Centermark -true- best regards Mads DK |
Thkanks Mads |
Fixed: .fixed 0004377 |
user training issue. |
| 2020-06-18 12:08 | Retus | New Issue | |
| 2020-06-19 18:01 | madslethdanielsen | Note Added: 0014570 | |
| 2020-06-20 07:07 | Retus | Note Added: 0014572 | |
| 2020-06-20 08:05 | Retus | Note Added: 0014573 | |
| 2020-06-20 13:54 | Retus | Fixed in Version | => 0.19 |
| 2020-06-20 13:56 | Retus | OS Version | => 10 |
| 2020-06-20 14:14 | Retus | Note Edited: 0014573 | |
| 2020-06-20 14:16 | Retus | Tag Attached: 0.19 | |
| 2020-06-21 12:46 | wandererfan | Severity | major => trivial |
| 2020-06-21 12:46 | wandererfan | Status | new => resolved |
| 2020-06-21 12:46 | wandererfan | Resolution | open => no change required |
| 2020-06-21 12:46 | wandererfan | Note Added: 0014575 | |
| 2020-06-21 12:51 | wandererfan | Relationship added | has duplicate 0004376 |
| 2020-06-26 17:15 | Kunda1 | Status | resolved => closed |
