| 0004378 | PartDesign | Bug | public | 2020-06-18 16:09 | 2021-03-03 11:51 |
| Reporter | cappu | Assigned To | |||
| Platform | linux | OS | Xubuntu | OS Version | 20.04 |
| Summary | 0004378: Crash after changing a pocket-size | ||||
| Description | Crash after changing a size-parameter in a sketch and close sketch (cpu gets 100% load and memory runs full) I am not sure if ths issue is found before as I do not know how to name it. But on my PC it is very simple to reproduce. | ||||
| Steps To Reproduce | 1) open RegalBuero (copy).FCStd 2) change WS to part-design 3) open last sketch043: RegalBuero/P2_KeinteilBoxen../B8_BodenHinten001/Seitenloecher/Sketch043 4) In this sketch043 change the very right-side hight-parameter from 32,8 to 33mm 5) close the sketch 6) look on cpu and RAM. On my PC CPU become 100% load (after aprox 5sec) and RAM starts slowly overflow (approx 30sec left until complete overflow) | ||||
| Additional Information | I use appimage file. If size of hight-parameter is less than 33 mm, no problems occur. 33mm and bigger seems to be a problem which is not catch in code. I created this 3d-model last week and updated appimage-version 1 time. With current version of FreeCad and at least one version before the issue occurs on my PC. Hope you can reproduce it on your PC. | ||||
| Tags | #pending-forum, 0.19, crash, Part Design | ||||
| FreeCAD Information | OS: Ubuntu 20.04 LTS (XFCE/xubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21654 (Git) AppImage Build type: Release Branch: master Hash: ddf0cf3136a6c5a459abae4bf1f9c714f6f45c86 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
@cappu where is the forum thread (as per our bugtracker guidelines)? Please open one next time before opening a ticket. Please open a thread now and link back to this ticket. Also add the forum thread to this ticket so we can track it. |
Also there is no file (RegalBuero (copy).FCStd) attached to this ticket to test |
Hello, Thanks for taking care. Please find attached file (hope it works now) No thread at the moment because in description it is description it is described if clearly a bug, it can be directly added here. But I will create a forum thread... I tried today with latest version, and crash still happens on my PC OS: Ubuntu 20.04 LTS (XFCE/xubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21764 (Git) AppImage Build type: Release Branch: master Hash: ccea55a65512d37081d708d6f504d0c4d182a9e0 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) Best regars |
Hm, looks like I do something wrong at adding the file. Filesize 1,6MB. No error. Green bar under file. But when I go over the attached file is says: html> <head><title>413 Request Entity Too Large</title></head> <body bgcolor="white"> <center><h1>413 Request Entity Too Large</h1> |
I already removed most parts of the model. Is there a different way to add the file? |
Tried to create a forum thread. But here an error comes when trying to add the file. (see screenshot) But without file, it does not make sense to talk about (Description: On Increasing a pocket size, computer crashes??? ). Is there a possibility to send you the model? |
Datei siehe https://www.magentacloud.de/lnk/ahAhDTWN |
Forum Link: https://forum.freecadweb.org/viewtopic.php?f=19&t=48101 (hope it is the correct forum. I have not found one to verify bugs) |
Related partial fix: FreeCAD master 31b1ad87 |
Trying to add attachment |
This ticket has been migrated to GitHub as issue 6077. |
FreeCAD: master 31b1ad87 2020-07-02 15:46:16 Details Diff |
Sketcher: Augment malformed constraint messages =============================================== Enable a user recomputing an object/document to identify which sketch has the malformed constraints. |
Affected Issues 0004378 |
| mod - src/Mod/Sketcher/App/Sketch.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/Sketch.h | Diff File | ||
| 2020-06-18 16:09 | cappu | New Issue | |
| 2020-06-18 16:09 | cappu | Tag Attached: 0.19 | |
| 2020-06-18 16:09 | cappu | Tag Attached: crash | |
| 2020-06-18 16:09 | cappu | Tag Attached: Part Design | |
| 2020-06-26 17:09 | Kunda1 | Status | new => feedback |
| 2020-06-26 17:09 | Kunda1 | Note Added: 0014588 | |
| 2020-06-26 17:10 | Kunda1 | Note Added: 0014589 | |
| 2020-06-26 17:10 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-06-27 10:58 | cappu | Note Added: 0014596 | |
| 2020-06-27 10:58 | cappu | Status | feedback => new |
| 2020-06-27 11:06 | cappu | Note Added: 0014597 | |
| 2020-06-27 11:06 | cappu | File Added: image.png | |
| 2020-06-27 11:07 | cappu | Note Added: 0014598 | |
| 2020-06-27 11:22 | cappu | Note Added: 0014599 | |
| 2020-06-27 11:22 | cappu | File Added: Screenshot_2020-06-27_13-20-42.png | |
| 2020-06-27 12:50 | cappu | Note Added: 0014600 | |
| 2020-06-27 13:21 | cappu | Note Added: 0014601 | |
| 2020-07-02 18:07 | Kunda1 | Note Added: 0014614 | |
| 2020-07-02 18:08 | Kunda1 | Changeset attached | => FreeCAD master 31b1ad87 |
| 2020-07-02 18:19 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-07-02 18:21 | Kunda1 | Tag Attached: #pending-forum | |
| 2021-03-03 11:51 | Kunda1 | Note Added: 0015478 |
