| 0004389 | FEM | Bug | public | 2020-06-29 18:25 | 2020-12-03 22:52 |
| Reporter | HoWil | Assigned To | berndhahnebach | ||
| Summary | 0004389: Results pipeline is not automatically updated | ||||
| Description | The "Results pipeline" is not automatically updated after e.g. the underlying results form a Elmer simulation are updated. One has to change some values like the "Mode" from "Surface" to "Surface with Edges" in the "Result display options" to observe a change in the displayed result values. The performed change in the "Mode" settings should not result in different values. The saved results are not updated until some settings are changed!! | ||||
| Steps To Reproduce | + Open "FemCalculixCantilever3D_newSolver" from "Startpage" + Save the file anywhere + Toggle visibility of "SolverElmerResult" + Add Face "Box:Face2" to "FemConstraintFixed" + Doupleclick "SolverElmer", "Run" the simulation and "Close" the "SolverControl" Task-dialogue + Doubleclick "SolverElmerResult" to enter the "Result display options" + Change "Mode" from "Surface" to "Surface with Edges" and observe the change in the displayed result values. The performed change in the "Mode" settings should not result in different values. The saved results are not updated until some settings are changed!! | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=18&t=22576&p=183698&hilit=pipeline+update#p183698 https://forum.freecadweb.org/viewtopic.php?f=18&t=22576&hilit=pipeline+update&start=50#p183814 | ||||
| Tags | FEM, Pipeline, postprocessing, results, update, VTK | ||||
Please see https://forum.freecadweb.org/viewtopic.php?f=18&t=45887&p=414227#p413986 |
@HoWil Is it safe to close this ticket? |
@HoWil bump @berndhahnebach please advise |
@HoWil is there a commit(s) associated with this ticket? |
@HoWil bump |
Possibly fixed by the following commits: FreeCAD master b25f7f42 or FreeCAD master 2edabee0 |
Closing ticket |
FreeCAD: master 2edabee0 2020-01-27 00:41:33 Details Diff |
FEM: solver elmer, workaround for result reading |
Affected Issues 0004389 |
| mod - src/Mod/Fem/femsolver/elmer/tasks.py | Diff File | ||
FreeCAD: master b25f7f42 2020-04-27 08:40:58 Committer: GitHub Details Diff |
FEM: elmer tasks, fix result and output creation |
| 2020-06-29 18:25 | HoWil | New Issue | |
| 2020-06-29 18:25 | HoWil | Tag Attached: FEM | |
| 2020-06-29 18:25 | HoWil | Tag Attached: VTK | |
| 2020-06-29 18:25 | HoWil | Tag Attached: Pipeline | |
| 2020-06-29 18:25 | HoWil | Tag Attached: results | |
| 2020-06-29 18:25 | HoWil | Tag Attached: postprocessing | |
| 2020-06-29 18:25 | HoWil | Tag Attached: update | |
| 2020-07-07 06:49 | HoWil | Assigned To | => HoWil |
| 2020-07-07 06:49 | HoWil | Status | new => resolved |
| 2020-07-07 06:49 | HoWil | Resolution | open => fixed |
| 2020-07-07 06:49 | HoWil | Fixed in Version | => 0.19 |
| 2020-07-07 06:49 | HoWil | Note Added: 0014623 | |
| 2020-07-07 16:49 | abdullah | Note Added: 0014628 | |
| 2020-07-24 12:31 | Kunda1 | Note Added: 0014682 | |
| 2020-08-26 11:59 | Kunda1 | Note Added: 0014719 | |
| 2020-12-01 11:27 | Kunda1 | Note Added: 0015035 | |
| 2020-12-03 22:50 | Kunda1 | Note Added: 0015067 | |
| 2020-12-03 22:50 | Kunda1 | Changeset attached | => FreeCAD master b25f7f42 |
| 2020-12-03 22:51 | Kunda1 | Changeset attached | => FreeCAD master 2edabee0 |
| 2020-12-03 22:52 | Kunda1 | Assigned To | HoWil => berndhahnebach |
| 2020-12-03 22:52 | Kunda1 | Status | resolved => closed |
| 2020-12-03 22:52 | Kunda1 | Note Added: 0015068 |
