| 0004392 | Arch | Bug | public | 2020-06-30 01:25 | 2020-07-13 19:37 |
| Reporter | vanuan | Assigned To | yorik | ||
| Summary | 0004392: Invisible walls aren't rendered on a TechDraw page when ArchView render mode is solid | ||||
| Description | When making a wall invisible and render mode solid, it isn't rendered on a page using ArchView section. But it is rendered when render mode is wireframe. I expect that the number of rendered objects is the same for wireframe and solid modes. | ||||
| Steps To Reproduce | 1. (Sketcher) Create a sketch 2. (Arch) Create a wall from a sketch 3. (Arch) Create a section from a wall 4. (TechDraw) Create a page 5. (TechDraw) Put ArchView on a page with render mode = wireframe 6. (Model) Make a wall invisible 7. (Model) Change ArchView render mode to solid | ||||
| FreeCAD Information | OS: Debian GNU/Linux 9 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21776 (Git) Build type: Unknown Branch: master Hash: 79e11ce8a1c382d92af39d58dbd7e7ccc8c0fefa Python version: 3.7.6 Qt version: 5.13.2 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
Apparently, when I set "All on" to true, it is being shown even if render mode is solid. But this setting, apparently only affects "Solid" mode. When I switch to "Coin" or "Coin mono" render mode, it's not rendering hidden objects. |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=35&t=48263 |
Pull request: https://github.com/FreeCAD/FreeCAD/pull/3674 |
Merged |
| 2020-06-30 01:25 | vanuan | New Issue | |
| 2020-06-30 01:25 | vanuan | File Added: solid_render_mode.FCStd | |
| 2020-06-30 02:11 | vanuan | Note Added: 0014604 | |
| 2020-07-01 16:02 | vanuan | Note Added: 0014609 | |
| 2020-07-02 18:00 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-07-06 02:45 | vanuan | Note Added: 0014617 | |
| 2020-07-13 17:16 | vanuan | Note Added: 0014645 | |
| 2020-07-13 19:24 | yorik | Changeset attached | => FreeCAD master 07406448 |
| 2020-07-13 19:24 | yorik | Note Added: 0014646 | |
| 2020-07-13 19:24 | yorik | Assigned To | => yorik |
| 2020-07-13 19:24 | yorik | Status | new => closed |
| 2020-07-13 19:24 | yorik | Resolution | open => fixed |
| 2020-07-13 19:37 | Kunda1 | Tag Detached: #pending-forum |
