0004397FreeCADBugpublic2022-02-06 17:50
ReporterFizik Assigned To
PrioritylowSeverityminorReproducibilityalways
Status resolvedResolutionreopened
OSWindows 10OS VersionBuild 19041.329
Product Version0.18
Target Version0.20
Summary0004397: Extensions module directory lacking from module paths on startup
DescriptionModules installed (by the Extension Manager) in the user Python modules directory %appdata%\FreeCAD\Mod are not accessible by means of the Python console (nor are they available to macros loaded into the workbench) when FreeCAD is started without command line options (e.g. from the start menu after a fresh install).
Things work fine when starting with the --module-path option, like
> path\to\FreeCAD.exe -M %appdata%\FreeCAD\Mod
Steps To ReproduceThis description is pretty arbitrary, but it is what I stumbled across.
  1. Get a fresh install of FreeCAD 0.18.4 on Windows 10.
  2. Install, by means of the Extension Manager, A2+. This drops a Python module directory A2plus in your %appdata%\FreeCAD\Mod directory.
  3. Start FreeCAD (from the Windows Menu, i.e. without command line options).
  4. In the Python console, type
  5.
       >>> import A2plus
       The interpreter reports ModuleNotFoundError on A2plus for the line entered.
  6. Quit FreeCAD, and restart with the extension modules directory passed as an additional Python module path, e.g.
  7.
    > & "$env:ProgramFiles\FreeCAD 0.18\bin\FreeCAD.exe" -M "$env:AppData\FreeCAD\Mod"
  8. In FreeCAD, try accessing A2+ from the Python Console again,
  9.
    >>> import A2plus
    The module is now accessible (and can be listed, e.g. dir(A2plus)).
FreeCAD InformationOS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Hash: 980bf9060e28555fecd9e3462f68ca74007b70f8
Python version: 3.6.6
Qt version: 5.6.2
Fizik
2020-07-02 15:13
reporter   ~0014612
Please delete this. I learned what I did wrong.
openBrain
2020-07-07 16:22
developer   ~0014625
@Fizik : please tell us what you did wrong so everybody will take advantage of this. I'll close ticket when done. Thx.
Fizik
2020-07-07 21:37
reporter   ~0014633
@openBrain The module is accessible by the name FreeCAD.A2plus (instead of A2plus without the prefix), and hence is imported by
import FreeCAD.A2plus
(I got myself fooled by the — apparently outdated — example file [A2p_animation-example-script.py](https://forum.freecad.org/download/file.php?id=97981) from the [A2+ documentation wiki](https://wiki.freecad.org/A2plus_Workbench).)
2022-02-04 18:45
administrator   ~0016350
@openBrain where should we document this?
openBrain
2022-02-06 17:48
developer   ~0016366
@Kunda1 : It's purely related to A2plus so we don't really have room for that. At least the information is here. ;)
yorik
2022-03-03 13:55
administrator   ~0016919
This ticket has been migrated to GitHub as issue 6086.
2020-07-02 14:31 Fizik New Issue
2020-07-02 15:13 Fizik Note Added: 0014612
2020-07-07 16:22 openBrain Note Added: 0014625
2020-07-07 21:37 Fizik Note Added: 0014633
2020-07-07 21:38 Fizik Note Edited: 0014633
2022-02-04 18:45 Kunda1 Status new => resolved
2022-02-04 18:45 Kunda1 Resolution open => no change required
2022-02-04 18:45 Kunda1 Note Added: 0016350
2022-02-06 17:48 openBrain Status resolved => feedback
2022-02-06 17:48 openBrain Resolution no change required => reopened
2022-02-06 17:48 openBrain Note Added: 0016366
2022-02-06 17:50 openBrain Status feedback => resolved
