| 0004407 | FreeCAD | Bug | public | 2020-07-16 22:30 | 2021-02-06 06:32 |
| Reporter | ari_yagui | Assigned To | yorik | ||
| Summary | 0004407: Documentation: Problem Part.Wire | ||||
| Description | According the manual https://www.freecad.org/manual/a-freecad-manual.pdf (PAGE 163), W = Part.Wire([E1,E2,E3,E4]), must create a Wire, but its fails. | ||||
| Steps To Reproduce | Just write this in the Python console or Macro editor: | ||||
| Additional Information | I tested in 1) FreeCAD_0.19-21938-Linux-Conda_glibc2.12-x86_64.AppImage 2) FreeCAD_0.19.21937_x64_LP_12.1.6_PY3QT5-WinVS2015.7z 3) FreeCAD_0.19.21940-Win-Conda_vc14.x-x86_64.7z | ||||
| Tags | #pending, documentation, Part | ||||
| FreeCAD Information | OS: Ubuntu 20.04 LTS (XFCE/xubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21938 (Git) AppImage Build type: Release Branch: master Hash: 5666598a6be219830a992610243fe23144a61453 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: Spanish/Argentina (es_AR) | ||||
The problem is the PDF, in this lines:
These lines creates infinite lines, and must be a segment.
So, someone can close this issue? (And modifies the PDF manual?) Thanks!. |
Thank you. Next time please open a forum thread instead per the guidelines. CC @yorik |
@ari_yagui : in your snippet you don't create 'E3' & 'E4' edges (so obviously Part.Wire fails) while it is done in the tutorial. Please check. @Kunda1 : |
@yorik is there a commit associated with this ticket ? edit: nvm it's in the manual not in the code. |
This is not a commit. Just someone asked to fix the doc... And it was done already: https://wiki.freecad.org/Manual:Creating_and_manipulating_geometry |
| 2020-07-16 22:30 | ari_yagui | New Issue | |
| 2020-07-16 22:30 | ari_yagui | Tag Attached: Part | |
| 2020-07-17 01:47 | ari_yagui | Note Added: 0014653 | |
| 2020-07-19 09:03 | Kunda1 | Note Added: 0014657 | |
| 2020-07-19 09:03 | Kunda1 | Tag Attached: #pending | |
| 2020-07-19 09:03 | Kunda1 | Assigned To | => yorik |
| 2020-07-19 09:03 | Kunda1 | Status | new => confirmed |
| 2020-07-19 09:04 | Kunda1 | Target Version | => 0.19 |
| 2020-07-19 09:04 | Kunda1 | Tag Attached: documentation | |
| 2020-07-19 10:06 | Kunda1 | Summary | Problem Part.Wire => Documentation: Problem Part.Wire |
| 2020-07-25 09:53 | openBrain | Note Added: 0014686 | |
| 2020-07-25 09:53 | openBrain | Assigned To | yorik => |
| 2020-07-25 09:53 | openBrain | Status | confirmed => feedback |
| 2020-07-25 10:34 | openBrain | Note Edited: 0014686 | |
| 2020-07-25 10:34 | openBrain | Assigned To | => yorik |
| 2020-07-25 10:34 | openBrain | Status | feedback => assigned |
| 2020-11-18 15:12 | yorik | Status | assigned => closed |
| 2020-11-18 15:12 | yorik | Resolution | open => fixed |
| 2020-11-18 15:12 | yorik | Fixed in Version | => 0.19 |
| 2020-11-19 13:46 | Kunda1 | Note Added: 0015006 | |
| 2020-11-19 13:47 | Kunda1 | Note Edited: 0015006 | |
| 2020-11-19 13:48 | yorik | Note Added: 0015007 | |
| 2020-11-19 13:48 | yorik | Note Edited: 0015007 | |
| 2021-02-06 06:32 | abdullah | Target Version | => 0.20 |
