| 0004421 | FreeCAD | Patch | public | 2020-08-20 08:20 | 2021-02-21 11:29 |
| Reporter | marioamb | Assigned To | Kunda1 | ||
| Target Version | 0.19 | Fixed in Version | 0.19 | ||
| Summary | 0004421: Part.CompoundTools.Explode.explodeCompound access a property of a sometimes null object with an error | ||||
| Description | Python code, file "src/Mod/Part/CompoundTools/Explode.py". The "explodeCompound" function can be called in a context without assigning the "ViewObject" property, for example from a command line script. The error:
I attach the simple patch to the code to correct it. | ||||
| FreeCAD Information | OS: Debian GNU/Linux bullseye/sid (MATE/mate) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21619 (Git) Build type: Release Branch: master Hash: 58e459cde1a60365510f308d94405ce58c9b008d Python version: 3.8.5 Qt version: 5.14.2 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
Explode.patch (500 bytes)
--- ./src/Mod/Part/CompoundTools/Explode.py.orig 2020-08-20 09:56:20.501325332 +0200
+++ ./src/Mod/Part/CompoundTools/Explode.py 2020-08-20 09:56:55.732717600 +0200
@@ -20,6 +20,7 @@
cf.Base = compound_obj
cf.FilterType = 'specific items'
cf.items = str(i)
- cf.ViewObject.DontUnhideOnDelete = True
+ if cf.ViewObject is not None:
+ cf.ViewObject.DontUnhideOnDelete = True
features_created.append(cf)
return (group, features_created)
Submitted FreeCAD Pull Request 4501 |
Thanks @marioamb Sorry we missed this patch, it some how slipped through the cracks. Next time please open a forum thread first per our guidelines. Thanks again. |
FreeCAD: master 110860fa 2021-02-21 04:02:24 luz paz Committer: wwmayer Details Diff |
Part: Part.CompoundTools.Explode.explodeCompound access a property of... ...a sometimes null object with an error Python code, file `src/Mod/Part/CompoundTools/Explode.py` The `explodeCompound` function can be called in a context without assigning the `ViewObject` property, for example from a command line script. The error that is fixed by this patch. ``` Traceback (most recent call last): ... File "/opt/freecad/Mod/Part/CompoundTools/Explode.py", line 23, in explodeCompound cf.ViewObject.DontUnhideOnDelete = True AttributeError: 'NoneType' object has no attribute 'DontUnhideOnDelete'] ``` Patch submitted by marioamb. Fix 0004421 https://tracker.freecadweb.org/view.php?id=4421 |
Affected Issues 0004421 |
| mod - src/Mod/Part/CompoundTools/Explode.py | Diff File | ||
| 2020-08-20 08:20 | marioamb | New Issue | |
| 2020-08-20 08:20 | marioamb | File Added: Explode.patch | |
| 2021-02-21 03:54 | Kunda1 | Description Updated | |
| 2021-02-21 03:54 | Kunda1 | FreeCAD Information | OS: Debian GNU/Linux bullseye/sid (MATE/mate) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21619 (Git) Build type: Release Branch: master Hash: 58e459cde1a60365510f308d94405ce58c9b008d Python version: 3.8.5 Qt version: 5.14.2 Coin... => OS: Debian GNU/Linux bullseye/sid (MATE/mate) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21619 (Git) Build type: Release Branch: master Hash: 58e459cde1a60365510f308d94405ce58c9b008d Python version: 3.8.5 Qt version: 5.1... |
| 2021-02-21 03:59 | Kunda1 | Category | Bug => Patch |
| 2021-02-21 03:59 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-21 04:05 | Kunda1 | Note Added: 0015406 | |
| 2021-02-21 04:08 | Kunda1 | Assigned To | => Kunda1 |
| 2021-02-21 04:08 | Kunda1 | Status | new => assigned |
| 2021-02-21 11:00 | Changeset attached | => FreeCAD master 110860fa | |
| 2021-02-21 11:00 | guest | Note Added: 0015409 | |
| 2021-02-21 11:29 | Kunda1 | Status | assigned => closed |
| 2021-02-21 11:29 | Kunda1 | Resolution | open => fixed |
| 2021-02-21 11:29 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-02-21 11:29 | Kunda1 | Note Added: 0015410 |
