| 0004432 | FreeCAD | Bug | public | 2020-09-10 18:37 | 2020-09-11 17:30 |
| Reporter | PedjaS | Assigned To | realthunder | ||
| OS | Windows | OS Version | 8.1 | ||
| Summary | 0004432: Cutting array of cylinders into cube fails | ||||
| Description | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=50002 I have Created simple array of Cylinders and Cube, and I want to use array of Cylinders to cut holes into Cube. It fails. Instead cutting holes both objects vanish. This is not first time I have this issue. It started with upgrade to 0.19. Solution I received on forum was to create Array of Cylinders with Link array unchecked and it indeed works. Link array is checked by default. As it creates problem and it is hard to undo if problem is detected later in a project, my suggestion is to at least set it to be unchecked by default. | ||||
| Steps To Reproduce | Create Cube, Create Cylinder Make array of cylinders Try to Cut Cube with array of cylinders. It fails. Example file is attached. | ||||
| Tags | Clone | ||||
| FreeCAD Information | OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22284 (Git) Build type: Release Branch: master Python version: 3.8.5 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
PR submitted by realthunder https://github.com/FreeCAD/FreeCAD/pull/3848 Merged by wmayer in FreeCAD master 18c0d8ab |
FreeCAD: master 18c0d8ab 2020-09-06 08:01:16 Committer: wwmayer Details Diff |
Part: fix dangerous static_cast usage in view provider Because Gui::ViewProviderLink can be used to override the view provider of any object, it is not safe to assume view provider type without explicit checking. |
Affected Issues 0004432 |
| mod - src/Mod/Part/Gui/ViewProviderBoolean.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderCompound.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderMirror.cpp | Diff File | ||
| 2020-09-10 18:37 | PedjaS | New Issue | |
| 2020-09-10 18:37 | PedjaS | Tag Attached: Clone | |
| 2020-09-10 18:37 | PedjaS | File Added: holes.FCStd | |
| 2020-09-11 17:27 | Kunda1 | Assigned To | => realthunder |
| 2020-09-11 17:27 | Kunda1 | Status | new => assigned |
| 2020-09-11 17:28 | Kunda1 | Note Added: 0014743 | |
| 2020-09-11 17:28 | Kunda1 | Changeset attached | => FreeCAD master 18c0d8ab |
| 2020-09-11 17:30 | Kunda1 | Status | assigned => closed |
| 2020-09-11 17:30 | Kunda1 | Resolution | open => fixed |
| 2020-09-11 17:30 | Kunda1 | Fixed in Version | => 0.19 |
