| 0004436 | FreeCAD | Bug | public | 2020-09-15 08:06 | 2021-08-27 02:51 |
| Reporter | Roy_043 | Assigned To | |||
| Summary | 0004436: Points_Structure command does not work properly | ||||
| Description | As far as I understand things the Points_Structure command should sort the points in a point cloud. The current algorithm seems flawed as only the X and Y coordinates of a point are used in the sorting process and to determine the index of the point in the new point cloud. src\Mod\Points\Gui\Command.cpp Line 434:
Example: pt1: 0,0,0 pt2: 0,0,1 pt1 and pt2 will receive the same index in the structured point cloud. Which effectively means that pt1 is overwritten by pt2. Also the structured point cloud can have 'nan' vectors which the algorithm should only use temporarily. See the attached file.
| Steps To Reproduce | See description. | ||||
| Additional Information | Forum topic: https://forum.freecadweb.org/viewtopic.php?f=3&t=49668 | ||||
| FreeCAD Information | OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22262 (Git) Build type: Release Branch: master Hash: f56825c79f11b75648a7a0dcc8a9f52bb4574e61 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Dutch/Netherlands (nl_NL) | ||||
Something has gone wrong with the formatting of the description. Sorry for that. |
Conclusion (see forum discussion): 'As designed'. This ticket can be closed. |
Closing as requested. |
| 2020-09-15 08:06 | Roy_043 | New Issue | |
| 2020-09-15 08:06 | Roy_043 | File Added: Test_Points_Structure.FCStd | |
| 2020-09-15 08:10 | Roy_043 | Note Added: 0014755 | |
| 2020-12-08 21:33 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-12-08 21:34 | Kunda1 | Description Updated | |
| 2020-12-08 21:35 | Kunda1 | Target Version | => 0.19 |
| 2021-01-30 14:22 | Roy_043 | Note Added: 0015227 | |
| 2021-08-27 02:51 | chennes | Status | new => closed |
| 2021-08-27 02:51 | chennes | Resolution | open => won't fix |
| 2021-08-27 02:51 | chennes | Note Added: 0015873 |
