| 0004439 | Path | Feature | public | 2020-09-18 17:51 | 2020-10-06 23:30 |
| Reporter | chrisb | Assigned To | sliptonic | ||
| Summary | 0004439: Rename "Finish Depth" to "Finish Step Down" | ||||
| Description | "Depth" sounds as if it was a distance from the surface. This property is different: it is the last step down from e.g. a pocketing operation. This leads sometimes to confusion, see this forum post. | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22411 (Git) Build type: Release Branch: master Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c Python version: 3.8.5 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
FreeCAD: master 83c24d61 2020-10-06 15:05:08 Details Diff |
change final step down label for clarity issue 0004439 |
Affected Issues 0004439 |
| mod - src/Mod/Path/Gui/Resources/panels/PageDepthsEdit.ui | Diff File | ||
| mod - src/Mod/Path/Gui/Resources/panels/SurfaceEdit.ui | Diff File | ||
FreeCAD: master d06d5687 2020-10-06 23:02:05 Committer: GitHub Details Diff |
Merge pull request 0003936 from sliptonic/bug/finshsteplabel Path: change final step down label for clarity fixes 0004439 |
| 2020-09-18 17:51 | chrisb | New Issue | |
| 2020-10-06 23:04 | sliptonic | Assigned To | => sliptonic |
| 2020-10-06 23:04 | sliptonic | Status | new => closed |
| 2020-10-06 23:04 | sliptonic | Resolution | open => fixed |
| 2020-10-06 23:04 | sliptonic | Note Added: 0014782 | |
| 2020-10-06 23:30 | sliptonic | Changeset attached | => FreeCAD master d06d5687 |
| 2020-10-06 23:30 | sliptonic | Changeset attached | => FreeCAD master 83c24d61 |
| 2020-10-06 23:30 | sliptonic | Note Added: 0014784 |
