| 0004444 | Sketcher | Feature | public | 2020-09-26 15:40 | 2021-01-31 11:13 |
| Reporter | chrisb | Assigned To | openBrain | ||
| Priority | low | Severity | feature | Reproducibility | always |
| Summary | 0004444: Make vertical/horizontal constraints in "Constraint creation continue mode" aware of points | ||||
| Description | Currently vertical and horizontal constraints can applied to points. However, this is not possible in Constraint creation continue mode, where the constraint is selected before the points. This should be augmented to behave the same as arbitrary angled distance constraint. See forum discussion. | ||||
| Tags | #pending-PR | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22474 (Git) Build type: Release Branch: master Hash: a44f8ffd427fa9b23b1f00dbf62d66cd152cd774 Python version: 3.8.5 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
| 2020-09-26 15:40 | chrisb | New Issue | |
| 2020-09-26 15:40 | chrisb | Status | new => assigned |
| 2020-09-26 15:40 | chrisb | Assigned To | => abdullah |
| 2020-10-16 17:01 | openBrain | Assigned To | abdullah => openBrain |
| 2020-10-16 17:01 | openBrain | Note Added: 0014891 | |
| 2020-10-16 17:02 | openBrain | Tag Attached: #pending-PR | |
| 2020-10-21 15:30 | Changeset attached | => FreeCAD master 537089b3 | |
| 2020-10-21 15:30 | guest | Note Added: 0014917 | |
| 2020-10-21 15:42 | openBrain | Status | assigned => closed |
| 2020-10-21 15:42 | openBrain | Resolution | open => fixed |
| 2020-10-21 15:42 | openBrain | Fixed in Version | => 0.19 |
| 2021-01-31 11:13 | Kunda1 | Summary | Make vertical/horizontal constraintsin "Constraint creation continue mode" aware of points => Make vertical/horizontal constraints in "Constraint creation continue mode" aware of points |
