| 0004457 | PartDesign | Bug | public | 2020-10-12 05:21 | 2021-02-07 13:25 |
| Reporter | le_avion | Assigned To | |||
| Target Version | 0.19 | Fixed in Version | 0.19 | ||
| Summary | 0004457: Crash when selecting a line or face and then "select reference" while trying to Revolve | ||||
| Description | Can be reproduced at will. If I select a sketch and try to revolve it, if I select a line or a face then click on Select Reference... in the dialog freeCAD crashes. I've attache a simple sketch as an example. | ||||
| Steps To Reproduce | 1. Start freeCAD 2. Create a new document. 3. Switch to Part Design 4. Create a simple sketch and close out of it. 5. In the Model tab select the sketch. 6. In the Tasks click on Revolution or click on the "Revolve a selected sketch" in the toolbar. 7. Click on any line or face in the sketch. 8. In the "Revolution parameters" dialog box, in the Axis drop-down, select "Select reference..." 9. Crash | ||||
| Tags | crash, Part Design | ||||
| FreeCAD Information | OS: KDE Flatpak runtime Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14555 (Git shallow) Build type: Release Branch: (HEAD detached at 783e134) Hash: 783e1346c7a078f5265c3f0c6a927d09a8c1fe70 Python version: 3.7.4 Qt version: 5.14.2 Coin version: 4.0.0 OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
I now tested this issue with version 0.19 and it crashes just the same. OS: Ubuntu Core 16 (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22133 (Git) Build type: Unknown Branch: master Hash: a6df94e37fb4f6595b4674600c22a2e31a56e0a0 Python version: 3.5.2 Qt version: 5.5.1 Coin version: 4.0.0a OCC version: 7.4.0 Locale: English/UnitedStates (en_US) |
Please post to forum to generate discussion (per our guidelines at the top of this page). Thanks. |
Changed ticket product version from 0.18 to 0.19 |
Can't reproduce based on mentioned procedure OS: Ubuntu 18.04.5 LTS (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. (20/10/06) Build type: Release Branch: unknown Hash: 566d32177a831855a23d19b013ae96bba42c5a02 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/France (fr_FR) |
Thread created for discussion: https://forum.freecadweb.org/viewtopic.php?f=8&t=51139 |
The discussion thread I created is here: https://forum.freecadweb.org/viewtopic.php?f=3&t=51132 wmayer was able to reproduce the crash and committed a fix: http://github.com/FreeCAD/FreeCAD/commit/b33f92898 This is amazing how fast a fix was committed. Thank you all for the help! |
I verified with the daily and wmayer's fix indeed eliminated the crash. |
FreeCAD master b33f9289 |
Closing. Attached commit ticket. Marked the forum thread [Solved] |
FreeCAD: master b33f9289 2020-10-14 13:20:52 Details Diff |
PartDesign: [skip ci] Improve revolution function + Fix hard crash when selecting an edge or face of the created feature before selecting option to choose a reference. + In ProfileBased::getAxis() convert OCCT into FreeCAD exception to simplify handling of calling instances. + Change return value of getReferencedSelection() from void to bool to mkae it easier for calling instance to detect if the selection failed. This is needed to avoid to add invalid items to the combo box of the revolution task panel |
Affected Issues 0004457 |
| mod - src/Mod/PartDesign/App/FeatureSketchBased.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ReferenceSelection.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ReferenceSelection.h | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskRevolutionParameters.cpp | Diff File | ||
| 2020-10-12 05:21 | le_avion | New Issue | |
| 2020-10-12 05:21 | le_avion | Tag Attached: 0.18 | |
| 2020-10-12 05:21 | le_avion | Tag Attached: crash | |
| 2020-10-12 05:21 | le_avion | Tag Attached: Part Design | |
| 2020-10-12 05:21 | le_avion | File Added: simple sketch.FCStd | |
| 2020-10-13 02:18 | le_avion | Note Added: 0014838 | |
| 2020-10-13 03:23 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-10-13 03:24 | Kunda1 | Status | new => feedback |
| 2020-10-13 03:24 | Kunda1 | Note Added: 0014841 | |
| 2020-10-13 03:24 | Kunda1 | Product Version | 0.18 => 0.19 |
| 2020-10-13 03:24 | Kunda1 | Description Updated | |
| 2020-10-13 03:24 | Kunda1 | Steps to Reproduce Updated | |
| 2020-10-13 03:24 | Kunda1 | FreeCAD Information | OS: KDE Flatpak runtime Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14555 (Git shallow) Build type: Release Branch: (HEAD detached at 783e134) Hash: 783e1346c7a078f5265c3f0c6a927d09a8c1fe70 Python version: 3.7.4 Qt version: 5.14.... => OS: KDE Flatpak runtime Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14555 (Git shallow) Build type: Release Branch: (HEAD detached at 783e134) Hash: 783e1346c7a078f5265c3f0c6a927d09a8c1fe70 Python version: 3.7.4 Qt versio... |
| 2020-10-13 03:24 | Kunda1 | Note Added: 0014842 | |
| 2020-10-13 15:14 | openBrain | Note Added: 0014843 | |
| 2020-10-14 12:56 | Kunda1 | Note Added: 0014849 | |
| 2020-10-14 12:57 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-10-14 12:57 | Kunda1 | Tag Detached: 0.18 | |
| 2020-10-14 12:57 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-10-14 15:27 | le_avion | Note Added: 0014853 | |
| 2020-10-14 15:27 | le_avion | Status | feedback => new |
| 2020-10-19 06:00 | le_avion | Note Added: 0014911 | |
| 2021-02-07 13:20 | Kunda1 | Note Added: 0015295 | |
| 2021-02-07 13:20 | Kunda1 | Changeset attached | => FreeCAD master b33f9289 |
| 2021-02-07 13:21 | Kunda1 | Tag Detached: #pending-forum | |
| 2021-02-07 13:25 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-02-07 13:25 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-07 13:25 | Kunda1 | Note Added: 0015296 | |
| 2021-02-07 13:25 | Kunda1 | Status | new => closed |
| 2021-02-07 13:25 | Kunda1 | Resolution | open => fixed |
