| 0004458 | Path | Bug | public | 2020-10-12 17:23 | 2021-02-06 06:33 |
| Status | resolved | Resolution | fixed | ||
| Summary | 0004458: [PATH] Engrave 'start at vertex' gives wrong path | ||||
| Description | The engraving operation allows for changing the vertex to start at. Some values produce correct paths. Others produce paths that gouge the part. | ||||
| Steps To Reproduce | Create a cube. Create a job and add an engrave operation Select the four edges on the top face and add them to the base tab of the engrave The path should generate correctly. change the 'start at vertex' property to '3' and recompute The starting position is recalculcated but the path now gouges the part and misses one edge. | ||||
PR: https://github.com/FreeCAD/FreeCAD/pull/4136 |
FreeCAD master 07e2e8fc |
This ticket has been migrated to GitHub as issue 6113. |
| 2020-10-12 17:23 | sliptonic | New Issue | |
| 2020-10-12 17:52 | sliptonic | Summary | Engrave 'start at vertex' gives wrong path => [PATH] Engrave 'start at vertex' gives wrong path |
| 2020-10-12 17:57 | sliptonic | Project | FreeCAD => Path |
| 2020-12-13 16:28 | gauna | Note Added: 0015135 | |
| 2020-12-13 16:28 | gauna | Note Edited: 0015135 | |
| 2020-12-16 00:09 | sliptonic | Assigned To | => sliptonic |
| 2020-12-16 00:09 | sliptonic | Status | new => resolved |
| 2020-12-16 00:09 | sliptonic | Resolution | open => fixed |
| 2020-12-16 00:09 | sliptonic | Note Added: 0015151 | |
| 2020-12-22 00:48 | Kunda1 | Note Added: 0015168 | |
| 2021-02-06 06:33 | abdullah | Target Version | => 0.20 |
