| 0004459 | Path | Feature | public | 2020-10-15 02:31 | 2021-02-06 06:33 |
| Reporter | anka | Assigned To | |||
| Platform | mac | OS | macosx | OS Version | 10.16.7 |
| Summary | 0004459: annoying : confirmation popup window hidden behind main-window | ||||
| Description | trying to add tool-controllers if more than one path-job exists, pops up a confirmation window for selecting the path-job. this selection window is not modal, but hidden behind main window. (seems to happen only in mac version) see also : https://forum.freecadweb.org/viewtopic.php?f=3&t=51135 | ||||
| Steps To Reproduce | Gene gave a brief explanation that resumes best: 'I click the tool icon, my tool library pops up, I select a tool and create a controller. I am then asked which job gets the tool. The popup of last step is hidden behind main-window !!! There'e is an alternative (described by Chris): Select the pathjob **, edit it (double click), select 'Tools', then 'add', tool library pops up, select a tool and create a controller Doing it this way, I would find more logical if selected controller is created in the pathjob ** the procedure started with. For now, freecad also asks as final step to select a job. | ||||
| Tags | #pending | ||||
| FreeCAD Information | OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22670 (Git) Build type: Release Branch: master Hash: 12155f4aab09047c5697db0c1b3cf93b02edda03 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
