| 0004461 | Part | Bug | public | 2020-10-15 19:25 | 2020-10-16 14:03 |
| Reporter | hardrock | Assigned To | jmaustpc | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | x86-64 | OS | Ubuntu | OS Version | 18.04 |
| Summary | 0004461: Solid from Shell is not solid | ||||
| Description | There is "good shell", all shell operations done without errors. Now need to convert it to solid and cut something from that. Convertion to solid using Part - Solid from Shell have completed without any errors. Fruther operations has incorrect result. | ||||
| Steps To Reproduce | 1. Use Part - Create solid from shell to create solid object 2. Draw something, for example sketch with square and extrude it to solid 3. Cut extruded sketch from body from #1 - result incorrect | ||||
| Additional Information | Another way to get solid from shell - using Draft Upgrade also failed (will post as new issue) | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS (Unity:Unity7:ubuntu/unity) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Branch: unknown Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Russian/Russia (ru_RU) | ||||
Discussion thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=51203 |
Here is it |
I have uncompressed the archive and tested the file in today's FreeCAD 0.19 from the daily PPA, the object so called "OriginalShell", which you appear to think you had converted to a solid, however 1)it is still a shell and 2) it does not pass the Part WB check Geometry test, it contains errors. I am closing this ticket for now so it can be triaged in the forums first since it appears at this stage to be more of a help request rather than a bug. We can open this ticket again if a bug is found. Jim |
The object is not a solid 1)it is still a shell and 2) it does not pass the Part WB check Geometry test, it contains errors. I am closing this ticket for now so it can be triaged in the forums first since it appears at this stage to be more of a help request rather than a bug. We can open this ticket again if a bug is found. |
| 2020-10-15 19:25 | hardrock | New Issue | |
| 2020-10-15 21:18 | Kunda1 | Note Added: 0014877 | |
| 2020-10-15 21:18 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-10-16 04:23 | hardrock | Note Added: 0014881 | |
| 2020-10-16 04:23 | hardrock | File Added: 1_bug_solid_not_solid.tar.gz | |
| 2020-10-16 07:36 | jmaustpc | Note Added: 0014882 | |
| 2020-10-16 07:37 | jmaustpc | Note Edited: 0014882 | |
| 2020-10-16 07:39 | jmaustpc | Assigned To | => jmaustpc |
| 2020-10-16 07:39 | jmaustpc | Status | new => closed |
| 2020-10-16 07:39 | jmaustpc | Resolution | open => no change required |
| 2020-10-16 07:39 | jmaustpc | Note Added: 0014883 | |
| 2020-10-16 14:03 | openBrain | Tag Detached: #pending-forum |
