| 0004466 | Path | Bug | public | 2020-10-18 12:23 | 2021-02-03 18:26 |
| Reporter | anka | Assigned To | sliptonic | ||
| Platform | MacOSx | OS | OSX | OS Version | 10.16.7 |
| Summary | 0004466: Operation Depths of SetupSheet not stored in template | ||||
| Description | when creating a path-job template, setup sheet information stored in json template file does not correspond to selection. Only 3 selections are possible, Coolant mode'-property is missing, https://forum.freecadweb.org/viewtopic.php?f=15&t=51266#p440371 | ||||
| Steps To Reproduce | Save template - check generated json-code selecting 'Operation Heights' stores 'Coolant information' to the template file selecting 'Operation Depths' stores 'Operation Heights' to the template file (selecting 'Tool Rapid Speeds' works fine) Operation Depths cannot be stored. | ||||
| FreeCAD Information | OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22670 (Git) Build type: Release Branch: master Hash: 12155f4aab09047c5697db0c1b3cf93b02edda03 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
Moved to Path category. @sliptonic care to weigh in? |
https://github.com/FreeCAD/FreeCAD/pull/4157 |
pr 4157 |
| 2020-10-18 12:23 | anka | New Issue | |
| 2020-12-04 00:00 | Kunda1 | Project | FreeCAD => Path |
| 2020-12-04 00:01 | Kunda1 | Note Added: 0015073 | |
| 2020-12-17 22:26 | sliptonic | Note Added: 0015157 | |
| 2021-02-03 18:26 | sliptonic | Assigned To | => sliptonic |
| 2021-02-03 18:26 | sliptonic | Status | new => closed |
| 2021-02-03 18:26 | sliptonic | Resolution | open => fixed |
| 2021-02-03 18:26 | sliptonic | Note Added: 0015254 |
