| 0004492 | Expressions | Bug | public | 2020-11-13 15:44 | 2021-01-11 11:30 |
| Reporter | AndrewCSP | Assigned To | hyarion | ||
| Summary | 0004492: Spreadsheet deleted value remains in database | ||||
| Description | If I create a row in a spreadsheet and give the value an alias, say 'wireDia', then delete that row and create another row elsewhere, I cannot now use that deleted name in the new row. Worse still, if I access values in the model, wireDia is still listed as a value and can be used in the model, preserving its (unchangeable) last value. @openBrain has confirmed this bug exists in 0.19 Forum thread | ||||
| Steps To Reproduce | Create a row in a spreadsheet and fill in the alias, eg wireDia. Delete the row Try and use that alias in a new row. Also, it is still possible to see and use that alias in a model. | ||||
| Tags | spreadsheet | ||||
| FreeCAD Information | OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16146 (Git) Build type: Release Branch: (HEAD detached at 0.18.4) Hash: 980bf9060e28555fecd9e3462f68ca74007b70f8 Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
Here's a PR to fix the issue: https://github.com/FreeCAD/FreeCAD/pull/4232 |
FreeCAD: master d525b29f 2021-01-01 17:37:58 Details Diff |
[Spreadsheet] Remove alias from dynamic properties on removeRows/Columns When removing a row in a spreadsheet which has an assigned alias, the alias will not be removed from the list of dynamic properties. This makes it impossible to create a new alias which uses the same name even if the original was removed (using removeRows/removeColumns) Fixes 0004492 |
Affected Issues 0004492 |
| mod - src/Mod/Spreadsheet/App/PropertySheet.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/App/PropertySheet.h | Diff File | ||
| mod - src/Mod/Spreadsheet/App/Sheet.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/TestSpreadsheet.py | Diff File | ||
| 2020-11-13 15:44 | AndrewCSP | New Issue | |
| 2020-11-13 15:44 | AndrewCSP | Tag Attached: spreadsheet | |
| 2020-11-13 15:48 | openBrain | Status | new => acknowledged |
| 2020-11-13 15:48 | openBrain | Description Updated | |
| 2021-01-01 18:20 | hyarion | Note Added: 0015194 | |
| 2021-01-07 15:11 | Kunda1 | Assigned To | => hyarion |
| 2021-01-07 15:11 | Kunda1 | Status | acknowledged => assigned |
| 2021-01-11 11:30 | hyarion | Changeset attached | => FreeCAD master d525b29f |
| 2021-01-11 11:30 | hyarion | Note Added: 0015204 | |
| 2021-01-11 11:30 | hyarion | Status | assigned => closed |
| 2021-01-11 11:30 | hyarion | Resolution | open => fixed |
