| 0004495 | FreeCAD | Bug | public | 2020-11-16 01:23 | 2021-12-09 17:50 |
| Reporter | uwestoehr | Assigned To | uwestoehr | ||
| Summary | 0004495: Navigation cube is not clickable at its edges and corners | ||||
| Description | When clicking on the edge of the navigation cube (the chamfered area), the view should be rotated by 45°. This does not work. One can select the area but it turns the view by 90°. Here is an example: | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=52118 | ||||
| Tags | #tobeclosed | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23029 (Git) Build type: Release Branch: master Hash: 691f25904218e923d1cd70ab72743c40f9bb36c5 Python version: 3.6.8 Qt version: 5.12.6 Coin version: 4.0.0a OCC version: 7.4.0.beta Locale: German/Germany (de_DE) | ||||
Here is how the OCC NaviCube behaves: This is a screencast from CAD Builder, so OCC's NaviCube works as expected, the bug is in FreeCAD. |
Here is a PR that adds the missing clickable edge faces: https://github.com/FreeCAD/FreeCAD/pull/4502 Work is in progress |
FreeCAD master e58ee299 FreeCAD master 23747f9d FreeCAD master f525904c |
@uwestoehr can this ticket be closed? |
Fixed in master |
FreeCAD: master e58ee299 2021-02-21 05:16:09 Committer: wmayer Details Diff |
[Gui] improving NaviCube fixes bug 4495 - add missing edge faces - implement a proper rotation recipe -> rotate towards the nearest possible state - add preferences settings to turn off this new rotation behavior - get rid of transparent cube faces to avoid wrong clicks, this way also remove the backfaces - to make the edge faces fit, use triangles for the corners - expose cube size setting to preferences dialog - add new button to view backside - get rid of bitmaps because as reported in https://forum.freecadweb.org/viewtopic.php?f=3&t=52118&start=20#p481781 the x y z labels are not scaled on HiDPI screens moreover they are often "in they way" when you want to click on a corner and in principle they don't provide more info since we already have the CS with the axis labels - also fix an arithmetic overflow compiler warning - also rename 2 variables |
Affected Issues 0004495 |
| mod - src/Gui/DlgSettingsNavigation.cpp | Diff File | ||
| mod - src/Gui/DlgSettingsNavigation.ui | Diff File | ||
| mod - src/Gui/NaviCube.cpp | Diff File | ||
FreeCAD: master 23747f9d 2021-03-27 22:20:59 Committer: wmayer Details Diff |
fix animation issue SO's auto rotation has its own rotation logic that ends at fixed positions. This collides with the "to nearest" option whose aim is to rotate to the next sensible state taking into account from what position the rotation was started. Thus the solution is to disable SO's auto rotation while the cube is rotated. |
FreeCAD: master f525904c 2021-03-29 16:29:44 Details Diff |
Gui: concatenate rotations and apply the result once at the end |
| 2020-11-16 01:23 | uwestoehr | New Issue | |
| 2020-11-16 11:25 | uwestoehr | Note Added: 0014991 | |
| 2021-02-21 14:05 | uwestoehr | Note Added: 0015416 | |
| 2021-03-29 17:00 | Kunda1 | Note Added: 0015574 | |
| 2021-03-29 17:00 | Kunda1 | Changeset attached | => FreeCAD master e58ee299 |
| 2021-03-29 17:00 | Kunda1 | Changeset attached | => FreeCAD master 23747f9d |
| 2021-03-29 17:00 | Kunda1 | Changeset attached | => FreeCAD master f525904c |
| 2021-03-29 17:01 | Kunda1 | Note Added: 0015575 | |
| 2021-03-29 17:02 | Kunda1 | Tag Attached: #tobeclosed | |
| 2021-03-30 02:30 | uwestoehr | Assigned To | => uwestoehr |
| 2021-03-30 02:30 | uwestoehr | Status | new => resolved |
| 2021-03-30 02:30 | uwestoehr | Resolution | open => fixed |
| 2021-03-30 02:30 | uwestoehr | Note Added: 0015585 | |
| 2021-12-09 17:50 | wmayer | Status | resolved => closed |
| 2021-12-09 17:50 | wmayer | Fixed in Version | => 0.20 |
