| 0004498 | PartDesign | Bug | public | 2020-11-21 06:41 | 2021-02-06 06:43 |
| Reporter | robotarmy | Assigned To | |||
| Platform | x86 | OS | Mac OS | OS Version | 10.15.7 (19H2) |
| Summary | 0004498: Loft between sketches with inner and outer elements created in different order results in bad 3D geometry | ||||
| Description | When creating a loft, the order the sketch elements are created should not matter, but it does. Take the case of lofting between two sketches, with two circles each, for example, to make a kind of cylinder. In one sketch the inside was created first, and in the other sketch the outside was created first, the loft tries to cross over itself resulting in zero thickness geometry and a 'black part'. See forum post https://forum.freecadweb.org/viewtopic.php?p=449244#p449244 See updated limitations on wiki page for PartDesign Loft: https://wiki.freecadweb.org/index.php?title=PartDesign_AdditiveLoft&type=revision&diff=794134&oldid=763800 Thanks! | ||||
| Steps To Reproduce | See attached file | ||||
| Tags | #pending-forum, Loft | ||||
| FreeCAD Information | OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22756 (Git) Build type: Release Branch: master Hash: ce87f586ee36ffe8ebcdcd3947ced4ab389ae795 Python version: 3.8.6 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
