0004521FreeCADFeaturepublic2021-02-07 11:18
ReporterDrC Assigned To
Status newResolutionopen
PlatformHP laptopOSWindows 10
Target Version0.20
Summary0004521: When joining a polygon to the end of an arc a tangent is implied
DescriptionThis feature seems to activate at imperceptible movement of the mouse or stylus. It results in an arbitrary tangent side added at whatever length fits the algorithm arbitrating between the gratuitous tangent and the new side.
A more user friendly approach might be to require a mouse click to define the tangent length.
Steps To ReproduceSee my previous report - number to follow.
Additional InformationSee my previous report - number to follow.
Tags#post-to-forum, 0.19, Poly-line, UI
FreeCAD InformationOS: Windows 10 (10.0)
Version: 0.19.23141 (Git)
Hash: 0eba78d40096720f7a637a9a73c382a08b820bca
Python version: 3.8.6
Locale: English/United Kingdom (en_GB)
Relationships
related to 0004520 feedbackchennes Doubleclick when drawing a polygon seems to results in an unresolvable double point.
DrC
2020-12-24 14:18
reporter   ~0015179
Previous report was
0004520: Doubleclick when drawing a polygon seems to results in an unresolvable double point.
2021-01-31 12:09
administrator   ~0015243
Forum thread please
DrC
2021-02-05 05:38
reporter   ~0015273
Sorry - there was no thread to attach this to. I had a bug mid-job and needed to get it down while I could still remember how it happened.
I probably shouldn't even be here because I'm not a developer and not a professional bug fixer (any more) but merely trying to use FreeCad. Trouble is I feel an obligation to tell you about as bug when I see it even when (as it always will be) it's mid job and I'm doing something new.
A section headed 'report all bugs here' in the forum might help me - but would it help you?
I really need it to be a one step process unless you can't replicate it.
DrC
2021-02-05 06:28
reporter   ~0015274
https://forum.freecad.org/viewtopic.php?f=3&t=5236&p=474546#p474546
chennes
2021-02-07 03:39
administrator   ~0015283
I believe the OP means "polyLINE" rather than "polyGON" -- the effect is that there is an extra segment to your polyline if your cursor is positioned too close to the arc. The logic behind this construction eludes me. IMO, the OP is right, I don't think it should behave like this: I suspect it is an actual bug rather than a feature misbehaving, but this is probably something for @abdullah to look into.
DrC
2021-02-07 11:18
reporter   ~0015287
Confirm - polyLINE
Apologies.
Software I grew up with drew 'polygons' this way.
yorik
2022-03-03 13:55
administrator   ~0016976
This ticket has been migrated to GitHub as issue 6144.
2020-12-24 14:11 DrC New Issue
2020-12-24 14:18 DrC Note Added: 0015179
2020-12-25 11:37 DrC Tag Attached: 0.19
2020-12-25 11:37 DrC Tag Attached: Poly-line
2020-12-25 11:37 DrC Tag Attached: UI
2021-01-31 12:08 Kunda1 Relationship added related to 0004520
2021-01-31 12:09 Kunda1 Status new => feedback
2021-01-31 12:09 Kunda1 Note Added: 0015243
2021-01-31 12:09 Kunda1 Tag Attached: #post-to-forum
2021-02-05 05:38 DrC Note Added: 0015273
2021-02-05 05:38 DrC Status feedback => new
2021-02-05 06:28 DrC Note Added: 0015274
2021-02-07 03:39 chennes Note Added: 0015283
2021-02-07 11:18 DrC Note Added: 0015287
