| 0004524 | FreeCAD | Bug | public | 2021-01-02 13:39 | 2022-01-01 15:23 |
| Reporter | Roeland Huys | Assigned To | vejmarie | ||
| Priority | immediate | Severity | block | Reproducibility | always |
| Summary | 0004524: FreeCAD_0.19-23546 does not start on MacOS (Big Sur) | ||||
| Description | FreeCAD_0.19-23546-macOS-x86_64-conda.dmg does not start. Only the Freecad icon appears, but nothing happens. I had to kill the application. | ||||
| Steps To Reproduce | Install FreeCad Grant MacOS permission Start Freecad | ||||
I am also having this problem. Running MacOS Big Sur. |
same problem. so, when I started FreeCad I seen this logs into Console: |
Please follow this thread: https://forum.freecad.org/viewtopic.php?f=4&t=51345 @vejmarie should I keep this ticket open ? |
@Roeland Huys and @ctgreybeard can you reproduce this issue on the 0.19.3 release version? |
I am running 0.19-24291 without any problems. 0.19.3 hasn’t appeared in Homebrew yet so I haven’t tried it. |
Thanks for the re-test. I'm marking this one #tobeclosed since it seems like it's been resolved in the time since the original report. |
I tested Freecad 0.19 on MacOS Montery, and it starts up correctly. This issue can be closed. |
Thanks all for reporting and testing. Closing now. |
| 2021-01-02 13:39 | Roeland Huys | New Issue | |
| 2021-01-11 02:05 | ctgreybeard | Note Added: 0015203 | |
| 2021-01-12 06:58 | wearymax | Note Added: 0015206 | |
| 2021-01-31 11:55 | Kunda1 | Assigned To | => vejmarie |
| 2021-01-31 11:55 | Kunda1 | Status | new => assigned |
| 2021-01-31 11:55 | Kunda1 | Note Added: 0015238 | |
| 2021-01-31 11:56 | Kunda1 | Summary | FreeCAD_0.19-23546 does not start on MacOS => FreeCAD_0.19-23546 does not start on MacOS (Big Sur) |
| 2021-12-29 03:58 | chennes | Note Added: 0016151 | |
| 2021-12-29 17:13 | ctgreybeard | Note Added: 0016168 | |
| 2021-12-29 17:14 | chennes | Tag Attached: #tobeclosed | |
| 2021-12-29 17:17 | chennes | Note Added: 0016169 | |
| 2022-01-01 11:05 | Roeland Huys | Note Added: 0016174 | |
| 2022-01-01 15:23 | chennes | Status | assigned => closed |
| 2022-01-01 15:23 | chennes | Resolution | open => no change required |
| 2022-01-01 15:23 | chennes | Note Added: 0016175 | |
| 2022-01-01 15:23 | chennes | Tag Detached: #tobeclosed |
