| 0004533 | Sketcher | Feature | public | 2021-01-14 08:05 | 2021-02-06 06:58 |
| Reporter | emmanuelobrien | Assigned To | abdullah | ||
| Summary | 0004533: Preserve corner and constraints for sketch fillets | ||||
| Description | Currently the sketch fillet tool deletes any constraints associated with the two lines to be filleted. By leaving a vertex at the intersection of the two lines, we can instead preserve most constraints in reasonable ways. Discussion here: https://forum.freecadweb.org/viewtopic.php?f=8&t=54179 Created PR https://github.com/FreeCAD/FreeCAD/pull/4296 It currently only supports fillets on straight lines. I'm happy to look at the curved line case if you like this PR. | ||||
| FreeCAD Information | OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23701 (Git) Build type: Unknown Branch: sketch-fillet Hash: 34b981f867adbce7cd806f2ea031ec7a22b6cab4 Python version: 3.8.5 Qt version: 5.12.8 Coin version: 4.0.0 OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
PR by user lunkwill: https://github.com/FreeCAD/FreeCAD/pull/4296 Commits: FreeCAD master 86992f80 FreeCAD master f6f43b6f FreeCAD master 46feeb11 FreeCAD master 9fc31dfa FreeCAD master 7b9d9fdc FreeCAD master 6db77375 |
@abdullah Thank you! JFYI, I edited your note in order to use the correct markup for the commit links. When adding a hash, mantisbt isn't as sophisticated as Github. You need to put the hash within the following markup (reference):
Just for reference, I will also link each commit to this ticket by clicking on each separate one an linking to this ticket by associating the ticket number to the commit. This happens automagically when using the mantisbt markup trigger in the commit itself.Edit: forgot to mention, thank you @emmanuelobrien ! |
@Kunda1 Wait wait!! That is important information I need to get right. So, for manual referencing c:FreeCAD:hasnumber: understood. For the commit. Before including "fixes 0004533" in the commit used to work. I somehow thought this had stopped working. Do you mean this way of marking the commit? For the forum, the commit tag is no longer working. But that is unrelated to mantisbt. Did I get it right? ;) |
FreeCAD: master 86992f80 2021-02-03 14:11:02 j Committer: abdullah Details Diff |
Sketcher: Preserve corner and constraints for sketch fillets Currently the sketch fillet tool deletes any constraints associated with the two lines to be filleted. By leaving a vertex at the intersection, we can instead preserve most constraints in reasonable ways. Sketch fillet horizontal and vertical point-to-point constraint support Also better future compatibility for point constraints, and some minor tweaks. |
Affected Issues 0004533 |
FreeCAD: master f6f43b6f 2021-02-03 14:12:40 j Committer: abdullah Details Diff |
Sketcher: Constraint documentation |
| mod - src/Mod/Sketcher/App/Constraint.h | Diff File | ||
FreeCAD: master 46feeb11 2021-02-03 14:14:14 j Committer: abdullah Details Diff |
Sketch: new fillet Python support |
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
FreeCAD: master 9fc31dfa 2021-02-03 14:15:46 j Committer: abdullah Details Diff |
Sketcher: new Fillet - icon |
| mod - src/Mod/Sketcher/Gui/Resources/Sketcher.qrc | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/geometry/Sketcher_CreatePointFillet.svg | Diff File | ||
FreeCAD: master 7b9d9fdc 2021-02-03 14:25:01 j Committer: abdullah Details Diff |
Sketcher: new fillet UI command |
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Workbench.cpp | Diff File | ||
FreeCAD: master 6db77375 2021-02-03 14:30:39 j Committer: abdullah Details Diff |
Sketcher: Group tests in different directories |
| mod - src/Mod/Sketcher/CMakeLists.txt | Diff File | ||
| add - src/Mod/Sketcher/SketcherTests/TestSketchFillet.py | Diff File | ||
| add - src/Mod/Sketcher/SketcherTests/TestSketcherSolver.py | Diff File | ||
| add - src/Mod/Sketcher/SketcherTests/__init__.py | Diff File | ||
| mod - src/Mod/Sketcher/TestSketcherApp.py | Diff File | ||
| 2021-01-14 08:05 | emmanuelobrien | New Issue | |
| 2021-01-17 20:50 | emmanuelobrien | Description Updated | |
| 2021-01-19 04:31 | emmanuelobrien | Description Updated | |
| 2021-01-19 04:42 | emmanuelobrien | Description Updated | |
| 2021-02-04 07:17 | abdullah | Assigned To | => abdullah |
| 2021-02-04 07:17 | abdullah | Status | new => closed |
| 2021-02-04 07:17 | abdullah | Resolution | open => fixed |
| 2021-02-04 07:17 | abdullah | Fixed in Version | => 0.19 |
| 2021-02-04 07:17 | abdullah | Note Added: 0015266 | |
| 2021-02-04 09:34 | Kunda1 | Note Edited: 0015266 | |
| 2021-02-04 09:40 | Kunda1 | Note Added: 0015267 | |
| 2021-02-04 09:40 | Kunda1 | Changeset attached | => FreeCAD master 6db77375 |
| 2021-02-04 09:40 | Kunda1 | Changeset attached | => FreeCAD master 7b9d9fdc |
| 2021-02-04 09:41 | Kunda1 | Changeset attached | => FreeCAD master 9fc31dfa |
| 2021-02-04 09:41 | Kunda1 | Changeset attached | => FreeCAD master 46feeb11 |
| 2021-02-04 09:41 | Kunda1 | Changeset attached | => FreeCAD master f6f43b6f |
| 2021-02-04 09:41 | Kunda1 | Changeset attached | => FreeCAD master 86992f80 |
| 2021-02-04 09:42 | Kunda1 | Note Edited: 0015267 | |
| 2021-02-06 06:58 | abdullah | Note Added: 0015279 |
