| 0004575 | Arch | Bug | public | 2021-02-25 15:30 | 2021-02-26 12:12 |
| Reporter | AndrewA | Assigned To | yorik | ||
| Priority | low | Severity | minor | Reproducibility | random |
| Summary | 0004575: Window from sketch produces incorrect hole | ||||
| Description | When putting a window in a roof, the hole often works, but at times it produces the wrong hole. https://forum.freecadweb.org/viewtopic.php?f=23&t=56018&p=481865#p481865 | ||||
| Steps To Reproduce | To create the window I had a standard window in first, then changed the sketch to a custom one. Often this works fine, as the example attached did until I made it higher,then all changes to the image seem to not do anything. I cannot reliably reproduce the behaviour, although it has happened before. | ||||
| Additional Information | This is a minor bug as there is a work around, see the forum post above | ||||
| FreeCAD Information | OS: Debian GNU/Linux bullseye/sid (XFCE/xfce) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24212 (Git) AppImage Build type: Release Branch: master Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a Python version: 3.8.6 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United Kingdom (en_GB) | ||||
| 2021-02-25 15:30 | AndrewA | New Issue | |
| 2021-02-25 15:30 | AndrewA | File Added: Greenhouse_BugReport.FCStd | |
| 2021-02-25 19:59 | Kunda1 | Summary | Window from skecth produces incorrect hole => Window from sketch produces incorrect hole |
| 2021-02-25 20:08 | Kunda1 | Product Version | 0.19 => 0.20 |
| 2021-02-26 12:12 | Kunda1 | Assigned To | => yorik |
| 2021-02-26 12:12 | Kunda1 | Status | new => confirmed |
| 2021-02-26 12:12 | Kunda1 | Note Added: 0015440 |
