| 0004588 | FreeCAD | Patch | public | 2021-03-06 18:24 | 2021-03-11 19:43 |
| Reporter | garya | Assigned To | Kunda1 | ||
| Fixed in Version | 0.19 | ||||
| Summary | 0004588: correct non-standard use of sed -i argument in cMake/FindPySide2Tools.cmake | ||||
| Description | cMake/FindPySide2Tools.cmake uses a non-standard sed argument "-i" without an extension, causing a build to break on FreeBSD systems. It should be corrected to use POSIX standard syntax: change
to | ||||
| Steps To Reproduce | On a FreeBSD system: $ cat - <<EOF >temp.tmp > # comment line > Non comment line > EOF $ sed -i "/^# /d" temp.tmp sed: 1: "temp.tmp": undefined label 'emp.tmp' $ sed "/^# /d" temp.tmp >temp.tmp.tmp && mv temp.tmp.tmp temp.tmp $ cat temp.tmp Non comment line | ||||
| Tags | FreeBSD | ||||
| FreeCAD Information | OS: FreeBSD 11.4-RELEASE-p6 (XFCE/xfce) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.b2ca86d8d Build type: Release Python version: 3.7.9 Qt version: 5.15.2 Coin version: 4.0.0 OCC version: 7.5.0 Locale: C/Default (C) | ||||
patch-cMake_FindPySide2Tools.cmake (1,003 bytes)
--- cMake/FindPySide2Tools.cmake.orig 2021-03-05 13:59:26 UTC
+++ cMake/FindPySide2Tools.cmake
@@ -58,7 +58,7 @@ MACRO(PYSIDE_WRAP_UI outfiles)
# we follow the tool command with in-place sed.
ADD_CUSTOM_COMMAND(OUTPUT ${outfile}
COMMAND "${PYSIDE2UICBINARY}" ${UICOPTIONS} "${infile}" -o "${outfile}"
- COMMAND sed -i "/^# /d" "${outfile}"
+ COMMAND sed "/^# /d" "${outfile}" >"${outfile}.tmp" && mv "${outfile}.tmp" "${outfile}"
MAIN_DEPENDENCY "${infile}"
endif()
@@ -85,7 +85,7 @@ MACRO(PYSIDE_WRAP_RC outfiles)
ADD_CUSTOM_COMMAND(OUTPUT "${outfile}"
COMMAND "${PYSIDE2RCCBINARY}" ${RCCOPTIONS} "${infile}" ${PY_ATTRIBUTE} -o "${outfile}"
endif()
FreeCAD Pull Request 4592 |
FreeCAD master 971bb669 Waiting for SI plugin to close this ticket. |
SI didn't close ticket :( Closing manually |
FreeCAD: master 971bb669 2021-03-07 10:52:27 luz paz Committer: wwmayer Details Diff |
CMake: correct non-POSIX friendly 'sed-i' arg in FindPySide2Tools.cmake resolves 0004588 ticket: https://tracker.freecad.org/view.php?id=4588 Patch provided by 'garya' Tweaked comment to reflect the patch change. [skip ci] |
Affected Issues 0004588 |
| mod - cMake/FindPySide2Tools.cmake | Diff File | ||
| 2021-03-06 18:24 | garya | New Issue | |
| 2021-03-06 18:24 | garya | File Added: patch-cMake_FindPySide2Tools.cmake | |
| 2021-03-06 20:00 | Kunda1 | Note Added: 0015491 | |
| 2021-03-06 20:00 | Kunda1 | Assigned To | => Kunda1 |
| 2021-03-06 20:00 | Kunda1 | Status | new => assigned |
| 2021-03-08 13:26 | Kunda1 | Note Added: 0015495 | |
| 2021-03-08 13:27 | Kunda1 | Tag Attached: FreeBSD | |
| 2021-03-08 13:27 | Kunda1 | Tag Attached: #tobeclosed | |
| 2021-03-08 13:30 | Changeset attached | => FreeCAD master 971bb669 | |
| 2021-03-08 13:30 | guest | Note Added: 0015496 | |
| 2021-03-11 19:35 | Kunda1 | Status | assigned => closed |
| 2021-03-11 19:35 | Kunda1 | Resolution | open => fixed |
| 2021-03-11 19:35 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-03-11 19:35 | Kunda1 | Note Added: 0015500 | |
| 2021-03-11 19:43 | Kunda1 | Tag Detached: #tobeclosed |
