| 0004635 | FreeCAD | Bug | public | 2021-04-16 12:30 | 2021-04-21 21:47 |
| Reporter | lmitcheson | Assigned To | chrisb | ||
| Summary | 0004635: FreeCAD not responding on startup | ||||
| Description | When I first installed version 0.19 it worked, however, when trying to run it again all I get is a white screen and Windows advising that it isn't responding. I uninstalled it and rebooted, then reinstalled, the same problem occurrs now. | ||||
| Steps To Reproduce | Simply trying to start the program, everytime I freezes | ||||
| FreeCAD Information | Can't access this area of the application, but the FreeCAD.log file I generated reports 0.19, Libs: 0.19R24276 (Git) | ||||
FreeCAD.log (12,213 bytes)
Msg: FreeCAD 0.19, Libs: 0.19R24276 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021 FreeCAD is free and open-source software licensed under the terms of LGPL2+ license. FreeCAD wouldn't be possible without FreeCAD community. ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Time = Fri Apr 16 13:18:37 2021 Log: AppDataSkipVendor = true Log: AppHomePath = D:/Program Files/FreeCAD 0.19/ Log: AppIcon = freecad Log: AppTempPath = C:\Users\LMITCH~1\AppData\Local\Temp\ Log: BinPath = D:/Program Files/FreeCAD 0.19/bin\ Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-19 Log: BuildRevision = 24276 (Git) Log: BuildRevisionBranch = releases/FreeCAD-0-19 Log: BuildRevisionDate = 2021/03/11 19:48:53 Log: BuildRevisionHash = a88db11e0a908f6e38f92bfc5187b13ebe470438 Log: BuildVersionMajor = 0 Log: BuildVersionMinor = 19 Log: Console = 0 Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021 FreeCAD is free and open-source software licensed under the terms of LGPL2+ license. FreeCAD wouldn't be possible without FreeCAD community. ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Debug = 0 Log: DocPath = D:/Program Files/FreeCAD 0.19/doc\ Log: ExeName = FreeCAD Log: ExeVendor = FreeCAD Log: ExeVersion = 0.19 Log: LoggingConsole = 1 Log: LoggingFile = 1 Log: LoggingFileName = D:\Users\lmitcheson\AppData\Roaming\FreeCAD\FreeCAD.log Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page Log: PATH = C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\oracle\product\11.2.0\client_1\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\DTS\Binn\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\lmitcheson\AppData\Local\Microsoft\WindowsApps;C:\adb; Log: PythonSearchPath = D:\Program Files\FreeCAD 0.19\bin\python38.zip;D:\Program Files\FreeCAD 0.19\bin\DLLs;D:\Program Files\FreeCAD 0.19\bin\lib;D:\Program Files\FreeCAD 0.19\bin Log: RunMode = Gui Log: SplashAlignment = Bottom|Left Log: SplashInfoColor = #c8c8c8 Log: SplashScreen = freecadsplash Log: SplashTextColor = #ffffff Log: StartWorkbench = StartWorkbench Log: SystemParameter = D:\Users\lmitcheson\AppData\Roaming\FreeCAD\system.cfg Log: UserAppData = D:\Users\lmitcheson\AppData\Roaming\FreeCAD\ Log: UserHomePath = D:\Users\lmitcheson\Documents Log: UserParameter = D:\Users\lmitcheson\AppData\Roaming\FreeCAD\user.cfg Log: Verbose = Log: Create Application Log: Run App init script Log: Init: starting App::FreeCADInit.py Log: Init: Searching for modules... Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\AddonManager... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Arch... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Draft... done Log: Drawing became obsolete in 0.17; consider using TechDraw instead. Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Drawing... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Fem... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Idf... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Image... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Import... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Inspection... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Material... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Measure... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Mesh... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\MeshPart... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Part... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\PartDesign... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Path... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Points... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Raytracing... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Robot... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Show(Init.py not found)... ignore Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Sketcher... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Spreadsheet... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Start... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Surface... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\TechDraw... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Test... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Tux(Init.py not found)... ignore Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Web... done Log: Using D:\Program Files\FreeCAD 0.19\Mod as module path! Log: System path after init: Log: D:\Program Files\FreeCAD 0.19\bin Log: D:\Program Files\FreeCAD 0.19\Mod\AddonManager Log: D:\Program Files\FreeCAD 0.19\Mod\Arch Log: D:\Program Files\FreeCAD 0.19\Mod\Draft Log: D:\Program Files\FreeCAD 0.19\Mod\Drawing Log: D:\Program Files\FreeCAD 0.19\Mod\Fem Log: D:\Program Files\FreeCAD 0.19\Mod\Idf Log: D:\Program Files\FreeCAD 0.19\Mod\Image Log: D:\Program Files\FreeCAD 0.19\Mod\Import Log: D:\Program Files\FreeCAD 0.19\Mod\Inspection Log: D:\Program Files\FreeCAD 0.19\Mod\Material Log: D:\Program Files\FreeCAD 0.19\Mod\Measure Log: D:\Program Files\FreeCAD 0.19\Mod\Mesh Log: D:\Program Files\FreeCAD 0.19\Mod\MeshPart Log: D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD Log: D:\Program Files\FreeCAD 0.19\Mod\Part Log: D:\Program Files\FreeCAD 0.19\Mod\PartDesign Log: D:\Program Files\FreeCAD 0.19\Mod\Path Log: D:\Program Files\FreeCAD 0.19\Mod\Points Log: D:\Program Files\FreeCAD 0.19\Mod\Raytracing Log: D:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering Log: D:\Program Files\FreeCAD 0.19\Mod\Robot Log: D:\Program Files\FreeCAD 0.19\Mod\Show Log: D:\Program Files\FreeCAD 0.19\Mod\Sketcher Log: D:\Program Files\FreeCAD 0.19\Mod\Spreadsheet Log: D:\Program Files\FreeCAD 0.19\Mod\Start Log: D:\Program Files\FreeCAD 0.19\Mod\Surface Log: D:\Program Files\FreeCAD 0.19\Mod\TechDraw Log: D:\Program Files\FreeCAD 0.19\Mod\Test Log: D:\Program Files\FreeCAD 0.19\Mod\Tux Log: D:\Program Files\FreeCAD 0.19\Mod\Web Log: C:\Program Files (x86)\Common Files\Oracle\Java\javapath Log: D:\oracle\product\11.2.0\client_1\bin Log: C:\Windows\system32 Log: C:\Windows Log: C:\Windows\System32\Wbem Log: C:\Windows\System32\WindowsPowerShell\v1.0\ Log: C:\Windows\System32\OpenSSH\ Log: C:\Program Files\Intel\WiFi\bin\ Log: C:\Program Files\Common Files\Intel\WirelessCommon\ Log: C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common Log: C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR Log: C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\ Log: C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\ Log: C:\Program Files\Microsoft SQL Server\130\Tools\Binn\ Log: C:\Program Files\Microsoft SQL Server\130\DTS\Binn\ Log: C:\WINDOWS\system32 Log: C:\WINDOWS Log: C:\WINDOWS\System32\Wbem Log: C:\WINDOWS\System32\WindowsPowerShell\v1.0\ Log: C:\WINDOWS\System32\OpenSSH\ Log: C:\Users\lmitcheson\AppData\Local\Microsoft\WindowsApps Log: C:\adb Log: Log: Init: App::FreeCADInit.py done Log: Init: Creating Gui::Application and QApplication Log: Local server 'FreeCAD' started Log: OpenGL version is: 4.6 (4.6.0 - Build 27.20.100.8935) Log: Run Gui init script Log: Init: Running FreeCADGuiInit.py start script... Log: Init: Searching modules... Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\AddonManager... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Arch... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Draft... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Drawing... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Fem... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Idf(InitGui.py not found)... ignore Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Image... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Import... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Inspection... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Material... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Measure(InitGui.py not found)... ignore Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Mesh... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\MeshPart... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Part... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\PartDesign... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Path... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Points... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Raytracing... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Robot... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Show(InitGui.py not found)... ignore Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Sketcher... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Spreadsheet... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Start... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Surface... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\TechDraw... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Test... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Tux... done Log: Init: Initializing D:\Program Files\FreeCAD 0.19\Mod\Web... done Log: Init: Loading FreeCAD GUI Log: Init: Running FreeCADGuiInit.py start script... done Log: Init: Activating default workbench StartWorkbench Log: Loading GUI of Web module... done Log: Loading GUI of Start module... done Log: Loading Start module... done Log: Init: Showing main window Log: Main window restored Log: Show main window Log: Toolbars restored Log: 3Dconnexion device not attached. Log: Init: Entering event loop Log: Init: Processing command line files |
@lmitcheson Per the tracker guidelines we ask that you first report the issue on the forum. I've done that for you this time: https://forum.freecadweb.org/viewtopic.php?f=8&t=57997 |
| 2021-04-16 12:30 | lmitcheson | New Issue | |
| 2021-04-16 12:30 | lmitcheson | File Added: FreeCAD.log | |
| 2021-04-21 18:59 | Kunda1 | Note Added: 0015637 | |
| 2021-04-21 18:59 | Kunda1 | Tag Attached: #pending-forum | |
| 2021-04-21 21:47 | chrisb | Assigned To | => chrisb |
| 2021-04-21 21:47 | chrisb | Status | new => closed |
| 2021-04-21 21:47 | chrisb | Resolution | open => no change required |
