| 0004643 | FreeCAD | Bug | public | 2021-04-24 16:45 | 2022-01-22 21:57 |
| Reporter | noahk | Assigned To | |||
| Platform | MacOS | OS | Big Sur | OS Version | 11.2.3 |
| Summary | 0004643: Crash on save | ||||
| Description | Save crashes on MacOS. Previously version compiled a few weeks ago worked fine. Version compiled last night via 'brew upgrade' crashes. | ||||
| Steps To Reproduce | Create a new project, add something to it (eg circle on sketch). Cmd-s. Crash. Crash happens with file menu save as well. | ||||
| Additional Information | Process: FreeCAD [49009] Path: /usr/local/Cellar/freecad/HEAD-ae0a315/FreeCAD.app/Contents/MacOS/FreeCAD Identifier: ??? Version: 0.20.0 (0.20.0) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: FreeCAD [49009] Date/Time: 2021-04-24 09:21:20.078 -0700 OS Version: macOS 11.2.3 (20D91) Report Version: 12 Bridge OS Version: 3.0 (14Y908) Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: exc handler [49009] See backtrace in attached log1.txt | ||||
| Tags | #pending, #tobeclosed, macOS | ||||
| FreeCAD Information | OS: macOS 11.2 Word size of FreeCAD: 64-bit Version: 0.20.24779 (Git) Build type: Release Branch: master Hash: ae0a31542f4be57d3b9e22fb59d327e6e5ede822 Python version: 3.9.0 Qt version: 5.15.2 Coin version: 4.0.0 OCC version: 7.5.0 Locale: English/United States (en_US) | ||||
Crash occurs with both native and QT file save dialogs |
https://github.com/FreeCAD/homebrew-freecad/issues/177 |
The problem might be that your OCC version and FreeCAD have been built with different compilers. In this case the i/o streams can cause trouble. A workaround is to avoid to directly use the streams but first write the BRep file to the disk and from there copy the data to the project file. Therefore open the parameter editor and go to: BaseApp/Preferences/Mod/Part/General and create the boolean key DirectAccess settings its value to false. |
Put the backtrace of the OP in an attached txt file to workaround export issues log1.txt (1,240 bytes)
VM Regions Near 0x28:
__TEXT 10c2e0000-10c2f0000 [ 64K] r-x/r-x SM=COW /usr/local/Cellar/freecad/HEAD-ae0a315/FreeCAD.app/Contents/MacOS/FreeCAD
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0 libc++.1.dylib 0x0000000111d6ed52 std::__1::istreambuf_iterator<char, std::__1::char_traits<char> > std::__1::num_get<char, std::__1::istreambuf_iterator<char, std::__1::char_traits<char> > >::__do_get_signed<long>(std::__1::istreambuf_iterator<char, std::__1::char_traits<char> >, std::__1::istreambuf_iterator<char, std::__1::char_traits<char> >, std::__1::ios_base&, unsigned int&, long&) const + 50
1 libc++.1.dylib 0x00007fff2033bdd0 std::__1::basic_ostream<char, std::__1::char_traits<char> >::operator<<(int) + 272
2 libTKBRep.7.dylib 0x000000017db6b05e TopTools_ShapeSet::Write(TopoDS_Shape const&, std::__1::basic_ostream<char, std::__1::char_traits<char> >&) const + 110
3 Part.so 0x000000017b9eae48 Part::PropertyPartShape::SaveDocFile(Base::Writer&) const + 446
4 libFreeCADBase.dylib 0x000000010d86c06c Base::ZipWriter::writeFiles() + 96
5 libFreeCADApp.dylib 0x000000010d3861a0 App::Document::saveToFile(char const*) const + 1042
6 libFreeCADApp.dylib 0x000000010d385b70 App::Document::save() + 978
Hi @chrisb, can you recreate this issue? If not then it very well may be a dependency issue as wmayer writes in 0004643:0016079 |
Closing ticket in favor of https://github.com/FreeCAD/homebrew-freecad/issues/177 (as this is dependency problem) |
| 2021-04-24 16:45 | noahk | New Issue | |
| 2021-04-24 16:46 | noahk | Note Added: 0015644 | |
| 2021-11-29 16:14 | ipatch | Note Added: 0016057 | |
| 2021-12-12 15:30 | wmayer | Note Added: 0016079 | |
| 2021-12-12 15:31 | wmayer | Note Edited: 0016079 | |
| 2021-12-15 04:53 | chennes | Additional Information Updated | |
| 2021-12-15 09:39 | yorik | Note Added: 0016094 | |
| 2021-12-15 09:39 | yorik | File Added: log1.txt | |
| 2021-12-15 09:40 | yorik | Additional Information Updated | |
| 2021-12-15 09:44 | yorik | Note Edited: 0016094 | |
| 2022-01-22 21:51 | Kunda1 | Note Added: 0016241 | |
| 2022-01-22 21:53 | Kunda1 | Tag Attached: #pending | |
| 2022-01-22 21:53 | Kunda1 | Tag Attached: #tobeclosed | |
| 2022-01-22 21:53 | Kunda1 | Tag Attached: macOS | |
| 2022-01-22 21:57 | Kunda1 | Status | new => closed |
| 2022-01-22 21:57 | Kunda1 | Resolution | open => no change required |
| 2022-01-22 21:57 | Kunda1 | Note Added: 0016242 |
