| 0004648 | FreeCAD | Bug | public | 2021-04-29 17:11 | 2022-01-24 19:16 |
| Reporter | Spindoctor | Assigned To | |||
| Platform | AMD x64 | OS | Debian | OS Version | Bullseye (AppIma |
| Summary | 0004648: Polar Pattern of Loft does not work on certain objects | ||||
| Description | The rotate pattern features does not work for a loft on a specified object. It does work, when the clones generated by the Polar pattern overlap, but it fails when they don't. The behaviour is described in this forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=58097 Please find a file that contains an object with this problem attached to this bug report. | ||||
| Steps To Reproduce | To illustrate the behaviour, I added an octagon to Sketch001 in the file attached. When you drag the vertical line inside of the octagon, the clones will overlap - the polar pattern then works as expected. When you drag it back outside of the octagon, the polar pattern would fail again. | ||||
| Tags | #ready-for-migration, OCC Bug, Part Design, PolarPattern, Sketch | ||||
| FreeCAD Information | OS: Debian GNU/Linux bullseye/sid (GNOME/gnome-xorg) Word size of FreeCAD: 64-bit Version: 0.20.24693 (Git) AppImage Build type: Release Branch: master Hash: e01f0d25d5f3ef9ceb66aa087212121e9f2f2e8b Python version: 3.9.2 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.1 Locale: German/Austria (de_AT) | ||||
| 2021-04-29 17:11 | Spindoctor | New Issue | |
| 2021-04-29 17:11 | Spindoctor | Tag Attached: OCC Bug | |
| 2021-04-29 17:11 | Spindoctor | Tag Attached: Part Design | |
| 2021-04-29 17:11 | Spindoctor | Tag Attached: PolarPattern | |
| 2021-04-29 17:11 | Spindoctor | Tag Attached: Sketch | |
| 2021-04-29 17:11 | Spindoctor | File Added: Rotate Loft Problem 2.FCStd | |
