| 0004664 | Sketcher | Bug | public | 2021-05-20 19:12 | 2021-08-27 13:00 |
| Reporter | Petrikas | Assigned To | chennes | ||
| Priority | low | Severity | tweak | Reproducibility | always |
| Fixed in Version | 0.20 | ||||
| Summary | 0004664: Sketcher tooltips have hard-coded hotkey hints | ||||
| Description | Sketcher tooltips contain hard-coded hotkey hints. When the user changes hotkeys through Customization, the tooltips show old 'default' hotkey, which is misleading and causes confusion. Sketcher hotkey hints are very useful. Maybe it would be possible to have the tooltips pull the FreeCAD hotkey parameter? Original post: https://forum.freecadweb.org/viewtopic.php?f=34&t=58747#p505063 Dedicated forum thread: https://forum.freecadweb.org/viewtopic.php?f=34&t=61564 | ||||
| Steps To Reproduce | Hover over any of the following tools in Sketcher workbench: Create line Create polyline Create rectangle Trim edge Extend edge Carbon copy Toggle construction geometry Constrain coincident Constrain point onto object Constrain vertically Constrain horizontally Constrain parallel Constrain perpendicular Constrain tangent Constrain equal Constrain symmetrical Constrain horizontal Constrain vertical Constrain distance Constrain angle Close shape Connect edges Select associated constraints Select associated geometry Select redundant constraints | ||||
| Tags | sketcher, tooltips, UI | ||||
| FreeCAD Information | OS: Windows 10 Version 2009 Word size of FreeCAD: 64-bit Version: 0.20.24840 (Git) Build type: Release Branch: master Hash: 131cdd1e4ec5e1cc1ddd1ccce4435fe23dee68cf Python version: 3.8.6+ Qt version: 5.15.2 Coin version: 4.0.1 OCC version: 7.5.0 Locale: English/United Kingdom (en_GB) | ||||
@yorik how can we do this without triggering new translations of strings that have been translated? |
@yorik if we can't help but make this 'destructive' fix maybe we might as well coordinate it simultaneously with the effort to sort the .ui files so that they are tab-corrected. Meaning when traversing the dialog box via the tab button, each option is in the correct sequence (as opposed to jumping around the dialog box) |
Need to have a better look at where these are defined in order to propose a fix. But yes, pulling the shortcut keys from preferences is doable (we did it in draft some time ago), and yes it will change the translation strings, i dont think it's possible to avoid that... |
@chennes @carlopav maybe this could be on the FreeCAD Pull Request 4787 roadmap ? |
Opened dedicated forum thread for discussion: https://forum.freecadweb.org/viewtopic.php?f=34&t=61564 Also updated ticket summary |
Is this actually still true? I just tested and it's showing the correct (custom) shortcut for me. |
See https://github.com/FreeCAD/FreeCAD/pull/4995 |
This PR has been merged. |
| 2021-05-20 19:12 | Petrikas | New Issue | |
| 2021-05-20 19:12 | Petrikas | Tag Attached: sketcher | |
| 2021-05-20 19:12 | Petrikas | Tag Attached: UI | |
| 2021-05-20 19:14 | Petrikas | Description Updated | |
| 2021-05-20 19:14 | Petrikas | FreeCAD Information | => OS: Windows 10 Version 2009 Word size of FreeCAD: 64-bit Version: 0.20.24840 (Git) Build type: Release Branch: master Hash: 131cdd1e4ec5e1cc1ddd1ccce4435fe23dee68cf Python version: 3.8.6+ Qt version: 5.15.2 Coin version: 4.0.1 OCC version: 7.5... |
| 2021-05-20 19:43 | Kunda1 | Tag Attached: tooltips | |
| 2021-05-20 19:44 | Kunda1 | Note Added: 0015669 | |
| 2021-05-21 12:48 | Kunda1 | Note Added: 0015671 | |
| 2021-05-21 14:47 | yorik | Note Added: 0015672 | |
| 2021-08-25 14:43 | Kunda1 | Note Added: 0015861 | |
| 2021-08-25 15:16 | Kunda1 | Description Updated | |
| 2021-08-25 15:16 | Kunda1 | Note Added: 0015862 | |
| 2021-08-25 15:18 | Kunda1 | Status | new => acknowledged |
| 2021-08-25 15:25 | chennes | Note Added: 0015863 | |
| 2021-08-25 19:10 | chennes | Assigned To | => chennes |
| 2021-08-25 19:10 | chennes | Status | acknowledged => assigned |
| 2021-08-25 19:29 | chennes | Note Added: 0015866 | |
| 2021-08-27 13:00 | chennes | Status | assigned => closed |
| 2021-08-27 13:00 | chennes | Resolution | open => fixed |
| 2021-08-27 13:00 | chennes | Fixed in Version | => 0.20 |
| 2021-08-27 13:00 | chennes | Note Added: 0015877 |
