0004669FreeCADBugpublic2021-08-20 14:54
ReporterStepanD Assigned To
Product Version0.19
Summary0004669: Segfault every time I click "Edit Sketch"
DescriptionI have a small part I started building, but FreeCAD has crashed while I was editing the part sketch. Since then, opening the file and clicking "Edit sketch" (on the only sketch it has) leads to repeatable crash.
Steps To ReproduceStep 1: Start FreeCAD from commandline, with no additinoal flags.
Step 2: Open the offending file (attached to this bug)
Step 3: In the Tree View, right-click "Sketch"
Step 4: In the resulting pop-up menu, click "Edit Sketch"
FreeCAD then instantly crashes with segmentation fault.
StepanD
2021-05-29 14:39
reporter   ~0015679
I'm not seeing the attached file, maybe something went wrong with the upload (or I'm just misunderstanding the tracker). So re-uploading just in case.
StepanD
2021-05-29 14:40
reporter   ~0015680
Oh, I keep getting "APPLICATION ERROR 0000503 Invalid upload path. Directory either does not exist or not writable to webserver."
So I suppose upload doesn't work in the tracker :-(
2021-08-20 14:53
administrator   ~0015840
@StepanD tracker should be fixed now. But please open a forum thread before opening a ticket per our guidelines. First please check if this issue still exists a development build first
2021-05-29 02:25 StepanD New Issue
2021-05-29 14:39 StepanD Note Added: 0015679
2021-05-29 14:40 StepanD Note Added: 0015680
2021-08-20 14:36 Kunda1 Steps to Reproduce Updated
2021-08-20 14:53 Kunda1 Note Added: 0015840
2021-08-20 14:54 Kunda1 Status new => closed
2021-08-20 14:54 Kunda1 Resolution open => no change required
