| 0004671 | File formats | Bug | public | 2021-05-30 10:42 | 2021-05-30 12:49 |
| Reporter | stillpointx | Assigned To | Kunda1 | ||
| Summary | 0004671: Getting error **"gITF support requires OCCT 7.5.0 or later"** Looks like the Appimages aren't compiled with OCCT 7.5 | ||||
| Description | Just a heads up. Getting error **"gITF support requires OCCT 7.5.0 or later"** Looks like the Appimages aren't compiled with OCCT 7.5 ``` 05:10:04 <Import> ImportOCAF2.cpp(1134): Unnamed#untitled_Hex_Holder_I3Mk3 has null shape 05:10:04 Traceback (most recent call last): File "<string>", line 4, in <module> <class 'RuntimeError'>: gITF support requires OCCT 7.5.0 or later ``` System Used: OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24276 (Git) AppImage Build type: Release Branch: (HEAD detached at 0.19.1) Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438 Python version: 3.8.8 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
| Steps To Reproduce | Import STL file Select file File - Export ![]() | ||||
| Tags | 0.19, appimage, conversion, encoding, export, file format, linux, OCC 7.4, OCC 7.5 | ||||
Testing to see if this is still an issue on the 0.19.2 appimage. If it is we need to backport the OCC 7.5.2 update (to 0.19.3). @stillpointx for the time being please use the 0.20 development snapshots available via the https://github.com/FreeCAD/FreeCAD-Bundle/releases/tag/weekly-builds CC @looo |
0.19.2 is also OCC7.4.0 Added recommendation for OCC7.5.2 in https://forum.freecadweb.org/viewtopic.php?f=10&t=57659&p=506958#p506958 Closing ticket. |
| 2021-05-30 10:42 | stillpointx | New Issue | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: 0.19 | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: appimage | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: conversion | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: encoding | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: export | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: file format | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: linux | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: OCC 7.4 | |
| 2021-05-30 10:42 | stillpointx | Tag Attached: OCC 7.5 | |
| 2021-05-30 12:41 | Kunda1 | Note Added: 0015681 | |
| 2021-05-30 12:49 | Kunda1 | Assigned To | => Kunda1 |
| 2021-05-30 12:49 | Kunda1 | Status | new => closed |
| 2021-05-30 12:49 | Kunda1 | Resolution | open => no change required |
| 2021-05-30 12:49 | Kunda1 | Note Added: 0015682 |
