| 0004701 | FEM | Bug | public | 2021-07-05 00:35 | 2021-08-07 11:35 |
| Reporter | Gustavo Luchesi | Assigned To | Kunda1 | ||
| Priority | high | Severity | block | Reproducibility | always |
| Summary | 0004701: BUCKLING ANALYSIS FOR SHELL ELEMENTS WITHOUT RESULTS | ||||
| Description | Hi Everyone. I've been studing FEA on FreeCAD from 0.18 version. I installed the new version 0.19 and i've been had some problems to open results of Buckling analysis. On the last version (018) to solve it I was editing the .inp file 'n changing the *STATIC for *BUCKLE (with 3 modes for example), Run Calculix 'n i get results very well. But now, in 0.19 version, i've been trying to run the same problems 'n i get empty results on ccx_Results with this message NO RESULT OBJECT - FEM: Graphical bending stress output for beam or shell FEM meshes not yet supported. But if i open the .inp file created by FreeCAD in Caculix inp editor, it's run and i get all results in post-processor. | ||||
| Tags | 0.19, FEM | ||||
Hi Gustavo. Could you rephrase your bug report as per instructions on https://wiki.freecadweb.org/Tracker? Particularly: 1. Provide a file which works in 0.18 but not in 0.19 (you might have to post this on the forum or elsewhere for some reason) 2. Provide step by step instructions to replicate this bug. 3. Create a post in forum.freecadweb.org for this bug. Thank you. JNXD |
Waiting for response from OP |
Would it be possible to make a post on forum.freecadweb.org in FEM part of the forum? cheers bernd |
No response from OP. Closing ticket. Please open a forum thread as requested. |
| 2021-07-05 00:35 | Gustavo Luchesi | New Issue | |
| 2021-07-05 00:37 | Gustavo Luchesi | Note Added: 0015728 | |
| 2021-07-08 01:20 | jnxd | Note Added: 0015733 | |
| 2021-07-08 01:30 | jnxd | Note Edited: 0015733 | |
| 2021-07-08 01:33 | jnxd | Tag Attached: 0.19 | |
| 2021-07-08 01:33 | jnxd | Tag Attached: FEM | |
| 2021-07-21 20:41 | Kunda1 | Project | FreeCAD => FEM |
| 2021-07-21 20:43 | Kunda1 | Status | new => feedback |
| 2021-07-21 20:43 | Kunda1 | Note Added: 0015740 | |
| 2021-07-25 22:33 | berndhahnebach | Note Added: 0015750 | |
| 2021-08-07 11:35 | Kunda1 | Assigned To | => Kunda1 |
| 2021-08-07 11:35 | Kunda1 | Status | feedback => closed |
| 2021-08-07 11:35 | Kunda1 | Resolution | open => unable to reproduce |
| 2021-08-07 11:35 | Kunda1 | Note Added: 0015781 |
