| 0004720 | FEM | Feature | public | 2021-08-06 18:34 | 2021-08-06 20:44 |
| Reporter | NewJoker | Assigned To | berndhahnebach | ||
| Summary | 0004720: More than 3 yield points in FEM_MaterialMechanicalNonlinear | ||||
| Description | Currently only 3 yield points can be defined in FEM_MaterialMechanicalNonlinear (plasticity definition). It should be fairly simple to add a possibility to define more points so that a full stress-strain curve can be approximated. Ideally, there should be no limitation on the number of yield points at all. But if a limit can't be avoided due to coding issues then let's increase it significantly. Forum thread: https://forum.freecadweb.org/viewtopic.php?f=18&t=57382 Previous forum thread with the discussion about this limitation: https://forum.freecadweb.org/viewtopic.php?f=18&t=51756 | ||||
| Tags | FEM, material | ||||
| FreeCAD Information | OS: Windows 10 Version 2009 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24276 (Git) Build type: Release Branch: releases/FreeCAD-0-19 Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438 Python version: 3.8.6+ Qt version: 5.15.1 Coin version: 4.0.1 OCC version: 7.5.0 Locale: Polish/Poland (pl_PL) | ||||
| 2021-08-06 18:34 | NewJoker | New Issue | |
| 2021-08-06 18:34 | NewJoker | Tag Attached: FEM | |
| 2021-08-06 18:34 | NewJoker | Tag Attached: material | |
| 2021-08-06 20:43 | Kunda1 | Note Added: 0015776 | |
| 2021-08-06 20:44 | Kunda1 | Assigned To | => berndhahnebach |
| 2021-08-06 20:44 | Kunda1 | Status | new => assigned |
