| 0004796 | TechDraw | Bug | public | 2021-12-03 21:45 | 2022-01-28 13:42 |
| Reporter | sighfromnz | Assigned To | chennes | ||
| Platform | Windows | OS | Windows | OS Version | 10 |
| Fixed in Version | 0.19 | ||||
| Summary | 0004796: Error in DOCUMENT_TYPE field in TechDraw Ax_Landscape_ISO7200_Pep templates | ||||
| Description | The "Document type:" field in the title block cannot be changed away from "Mechanical assembly drawing". This appears to be to an error in the template. This is in templates:
But not in:
Also as a minor design issue: Isn't "Mechanical assembly drawing" a bit to specific for a template? | ||||
| Steps To Reproduce | 1. Open FreeCAD 0.20 (latest development version) 2. Go to the TechDraw workbench 3. Click on the "Insert Page using Template" folder button. 4. Select any of: A0_Landscape_ISO7200_Pep A1_Landscape_ISO7200_Pep A2_Landscape_ISO7200_Pep A4_Landscape_ISO7200_Pep 5. When the chart is in "frames mode" click on the green square next to the "Document type:" field in the title block. As a default it reads "Mechanical assembly drawing". 6. Edit the DOCUMENT_TYPE field with any text values. Click [OK] 7. You will notice that any text that you entered didn't replace "Mechanical assembly drawing", rather it just appends it to the end of this text. | ||||
| FreeCAD Information | OS: Windows 10 Version 2009 Word size of FreeCAD: 64-bit Version: 0.20.26155 (Git) Build type: Release Branch: master Hash: 0926a4148bcff11249fd4f56bc30256102ffe105 Python version: 3.8.6+ Qt version: 5.15.2 Coin version: 4.0.1 OCC version: 7.5.0 Locale: English/United States (en_US) | ||||
After grepping t6hrough the source this also shows up in:
These are user contributed templates. There are other versions of these templates available. You can modify the template and store it in an accessible location. |
Fixed with https://github.com/FreeCAD/FreeCAD/pull/4474 |
Solved by chennes https://github.com/FreeCAD/FreeCAD/pull/4474
| 2021-12-03 21:45 | sighfromnz | New Issue | |
| 2021-12-03 22:01 | sighfromnz | Note Added: 0016058 | |
| 2021-12-03 22:34 | sighfromnz | Note Edited: 0016058 | |
| 2022-01-25 20:24 | wandererfan | Assigned To | => wandererfan |
| 2022-01-25 20:24 | wandererfan | Status | new => feedback |
| 2022-01-25 20:24 | wandererfan | Note Added: 0016311 | |
| 2022-01-28 11:24 | bensay | Note Added: 0016320 | |
| 2022-01-28 13:42 | Kunda1 | Assigned To | wandererfan => chennes |
| 2022-01-28 13:42 | Kunda1 | Status | feedback => closed |
| 2022-01-28 13:42 | Kunda1 | Resolution | open => fixed |
| 2022-01-28 13:42 | Kunda1 | Fixed in Version | => 0.19 |
| 2022-01-28 13:42 | Kunda1 | Note Added: 0016321 |
