| 0004817 | Path | Bug | public | 2021-12-30 05:12 | 2022-01-19 18:11 |
| Reporter | anka | Assigned To | sliptonic | ||
| Fixed in Version | 0.20 | ||||
| Summary | 0004817: CAM Simulator fails | ||||
| Description | Last known version the problem did not appear : FreeCAD_weekly-builds-26554-OSX-x86_64-conda Now getting following error :
HINT : 1) opening an older file (containing a job) created with version 0.19 of FreeCad, the problem does not appear. 2) opening a file created with version 0.20 FreeCAD_weekly-builds-26554-OSX-x86_64-conda 2a) no problem when opening with version weekly-builds-26554 2b) problem when opening with version weekly-builds-26720 | ||||
| Steps To Reproduce | Create new file. WB PartDesign: create body create sketch draw simple sketch (eg. a circle (can be anything else) extrude to cylinder WB Path create path from created body create operation (eg profile (can be anything else) launch CAM Simulation fails | ||||
| Additional Information | Running the Python command 'Path_Simulator' failed: Traceback (most recent call last): File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 588, in Activated pathSimulation.Activate() File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 103, in Activate self.onJobChange() File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 459, in onJobChange for op in j.Operations.OutList: Cannot access attribute 'Operations' of deleted object | ||||
| FreeCAD Information | OS: macOS 10.16 Word size of FreeCAD: 64-bit Version: 0.20.26720 (Git) Build type: Release Python version: 3.9.9 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: C/Default (C) | ||||
Is there a forums discussion about this? |
Forum entry: https://forum.freecadweb.org/viewtopic.php?f=15&t=64926 |
https://github.com/FreeCAD/FreeCAD/commit/2e6437a961945cd1715a98cfaff63c59a7dc7212 |
| 2021-12-30 05:12 | anka | New Issue | |
| 2021-12-30 06:07 | chennes | Note Added: 0016171 | |
| 2021-12-30 06:07 | chennes | Tag Attached: #pending-forum | |
| 2021-12-31 04:48 | anka | Note Added: 0016173 | |
| 2022-01-01 03:16 | chennes | Tag Detached: #pending-forum | |
| 2022-01-03 10:52 | openBrain | Tag Attached: #pending-forum | |
| 2022-01-19 18:08 | Kunda1 | Note Added: 0016233 | |
| 2022-01-19 18:10 | Kunda1 | Note Edited: 0016233 | |
| 2022-01-19 18:10 | Kunda1 | Tag Detached: #pending-forum | |
| 2022-01-19 18:11 | Kunda1 | Assigned To | => sliptonic |
| 2022-01-19 18:11 | Kunda1 | Status | new => closed |
| 2022-01-19 18:11 | Kunda1 | Resolution | open => fixed |
| 2022-01-19 18:11 | Kunda1 | Fixed in Version | => 0.20 |
