| 0000523 | FreeCAD | Bug | public | 2011-12-06 14:20 | 2021-02-20 13:44 |
| Reporter | msynth | Assigned To | |||
| Summary | 0000523: Fillet Updates is failling! | ||||
| Description | Please change the height of the box and/or cylinder for three or four mm and you will see two different bugs. | ||||
| Tags | fillet, toponaming | ||||
| duplicate of | 0000922 | assigned | realthunder | Topological Naming |
2011-12-06 14:20
It's one and the same bug. The problem is when changing the box the fused object changes the order of its internal edges and thus the indices of the edges to be filleted are wrong. |
At the moment i recreate the fillet after each change in size of objects. Is there any possibility to avoid it or i should wait until fixing the bug? |
I guess it will take some time to implement a pleasant workaround for this issue since this not a trivial thing. |
Belongs to the greate problem of topological naming |
This is toponaming bug. Closing as it as a dupe. |
| 2011-12-06 14:20 | msynth | New Issue | |
| 2011-12-06 14:20 | msynth | File Added: Fillet-Bug.FCStd | |
| 2011-12-06 14:34 | wmayer | Note Added: 0001409 | |
| 2011-12-06 14:45 | msynth | Note Added: 0001410 | |
| 2011-12-06 18:36 | wmayer | Note Added: 0001411 | |
| 2012-12-20 20:01 |
Relationship added | child of 0000922 |
| 2012-12-20 20:02 |
Note Added: 0002698 | |
| 2012-12-20 20:02 |
Assigned To | => Jriegel |
| 2012-12-20 20:02 |
Status | new => assigned |
| 2017-05-30 22:57 | Kunda1 | Assigned To | Jriegel => jnxd |
| 2021-02-20 13:41 | Kunda1 | Tag Attached: fillet | |
| 2021-02-20 13:43 | Kunda1 | Assigned To | jnxd => |
| 2021-02-20 13:43 | Kunda1 | Status | assigned => closed |
| 2021-02-20 13:43 | Kunda1 | Resolution | open => duplicate |
| 2021-02-20 13:43 | Kunda1 | Note Added: 0015376 | |
| 2021-02-20 13:43 | Kunda1 | Relationship replaced | duplicate of 0000922 |
| 2021-02-20 13:44 | Kunda1 | Tag Attached: toponaming |
