| 0000054 | FreeCAD | Bug | public | 2009-12-12 19:14 | 2009-12-14 09:07 |
| Reporter | supiik | Assigned To | yorik | ||
| Priority | normal | Severity | crash | Reproducibility | N/A |
| Product Version | 0.9 | ||||
| Fixed in Version | 0.10 | ||||
| Summary | 0000054: Crash after playing with | ||||
| Description | Hi, crash was observed in 0.9 - 2646. I have created a cone. Than I chosen Offsets the active objects and Trim function. Best regards Peter | ||||
| Additional Information | Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1693, in action point,ctrlPoint = getPoint(self,arg) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 338, in getPoint point = snapPoint(target,point,args["Position"],args["CtrlDown"]) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 156, in snapPoint pt = fcgeo.findIntersection(j,k) File "/usr/lib/freecad/Mod/Draft/draftlibs/fcgeo.py", line 169, in findIntersection d = vec1.dot(toPlane) UnboundLocalError: local variable 'vec1' referenced before assignment Pick start point: Pick end point: Running the Python command 'Draft_Rotate' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1795, in Activated self.proceed() File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1816, in proceed self.arctrack = arcTracker(axis=self.axis) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 501, in __init__ self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation Cannot find type information for requested typeRunning the Python command 'Draft_Rotate' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1795, in Activated self.proceed() File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1816, in proceed self.arctrack = arcTracker(axis=self.axis) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 501, in __init__ self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation Cannot find type information for requested typeRunning the Python command 'Draft_Rotate' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1795, in Activated self.proceed() File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1816, in proceed self.arctrack = arcTracker(axis=self.axis) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 501, in __init__ self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation Cannot find type information for requested typeRunning the Python command 'Draft_Rotate' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1795, in Activated self.proceed() File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1816, in proceed self.arctrack = arcTracker(axis=self.axis) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 501, in __init__ self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation Cannot find type information for requested typeRunning the Python command 'Draft_Rotate' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1795, in Activated self.proceed() File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1816, in proceed self.arctrack = arcTracker(axis=self.axis) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 501, in __init__ self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation Cannot find type information for requested typePick distance: Illegal storage access... supiik@supiik-laptop:~$ | ||||
Hmm in this bug there is actually the same problem as the first one you reported (0000048), which is shown by the self.initrot = FreeCADGui.ActiveDocument.ActiveView.getViewer().getCamera().orientation line (that method was removed in latest revision), but using the trim tool on a cone indeed produces a crash. I'll take care of that... Thanks for reporting! |
Wow, I just discovered that writing # followed by a number creates a link to that bug number. cool! |
This bug is indeed due to the combination of Offset and Trim tools. Doing Offset on the cone did produce "non-valid" geometry (only one edge was offsetted, resulting in an "impossible" shape) which made the application crash when the Trim tool tried to check if the shape was closed. I now prevented the offset tool to work on objects with multiple faces (it wouldn't have produced any result anyway) It is now fixed in rev 2736 Thanks for reporting the bug, Peter! |
| 2009-12-12 19:14 | supiik | New Issue | |
| 2009-12-12 19:30 |
Status | new => assigned |
| 2009-12-12 19:30 |
Assigned To | => yorik |
| 2009-12-12 21:14 | yorik | Note Added: 0000058 | |
| 2009-12-12 21:15 | yorik | Note Added: 0000059 | |
| 2009-12-13 14:48 | yorik | Note Added: 0000062 | |
| 2009-12-13 14:48 | yorik | Status | assigned => resolved |
| 2009-12-13 14:48 | yorik | Fixed in Version | => 0.10 |
| 2009-12-13 14:48 | yorik | Resolution | open => fixed |
| 2009-12-14 09:07 | wmayer | Status | resolved => closed |
