| 0000622 | PartDesign | Feature | public | 2012-03-05 21:17 | 2021-02-06 06:43 |
| Reporter | electronlibre | Assigned To | |||
| Summary | 0000622: Add taper angle feature in pad and pocket | ||||
| Description | It would be nice to have a taper angle option in pad and pocket tools (Part design workbench), similar to that on Extrude (Part WB). | ||||
2012-04-29 05:53
TaperAngle_Pad.patch (27,938 bytes)
From a5036f1b89097d597cde84d6ff4605eca17120fe Mon Sep 17 00:00:00 2001
Date: Sun, 29 Apr 2012 09:45:19 +0200
Subject: [PATCH 1/2] adds TaperAngle to Pad
src/Mod/PartDesign/App/FeaturePad.cpp | 421 +++++++++++++++-----------
src/Mod/PartDesign/App/FeaturePad.h | 1 +
src/Mod/PartDesign/Gui/TaskPadParameters.cpp | 39 ++-
src/Mod/PartDesign/Gui/TaskPadParameters.h | 12 +-
src/Mod/PartDesign/Gui/TaskPadParameters.ui | 35 ++-
5 files changed, 308 insertions(+), 200 deletions(-)
diff --git a/src/Mod/PartDesign/App/FeaturePad.cpp b/src/Mod/PartDesign/App/FeaturePad.cpp
index 1a12c45..80075be 100644
--- a/src/Mod/PartDesign/App/FeaturePad.cpp
+++ b/src/Mod/PartDesign/App/FeaturePad.cpp
@@ -1,184 +1,239 @@
- * Copyright (c) 2010 Juergen Riegel <FreeCAD@juergen-riegel.net> *
- * This file is part of the FreeCAD CAx development system. *
- * This library is free software; you can redistribute it and/or *
- * modify it under the terms of the GNU Library General Public *
- * License as published by the Free Software Foundation; either *
- * version 2 of the License, or (at your option) any later version. *
- * This library is distributed in the hope that it will be useful, *
- * but WITHOUT ANY WARRANTY; without even the implied warranty of *
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
- * GNU Library General Public License for more details. *
- * You should have received a copy of the GNU Library General Public *
- * License along with this library; see the file COPYING.LIB. If not, *
- * write to the Free Software Foundation, Inc., 59 Temple Place, *
- * Suite 330, Boston, MA 02111-1307, USA *
-#include "PreCompiled.h"
-#ifndef _PreComp_
-//# include <Bnd_Box.hxx>
-//# include <gp_Pln.hxx>
-# include <BRep_Builder.hxx>
-# include <BRepBndLib.hxx>
-# include <BRepPrimAPI_MakePrism.hxx>
-# include <BRepBuilderAPI_Copy.hxx>
-# include <BRepBuilderAPI_MakeFace.hxx>
-//# include <Geom_Plane.hxx>
-# include <Handle_Geom_Surface.hxx>
-# include <TopoDS.hxx>
-# include <TopoDS_Solid.hxx>
-# include <TopoDS_Face.hxx>
-# include <TopoDS_Wire.hxx>
-# include <TopExp_Explorer.hxx>
-# include <BRepAlgoAPI_Fuse.hxx>
-# include <Precision.hxx>
-#endif
-#include <Base/Placement.h>
-#include <Mod/Part/App/Part2DObject.h>
-#include "FeaturePad.h"
-using namespace PartDesign;
-PROPERTY_SOURCE(PartDesign::Pad, PartDesign::Additive)
-Pad::Pad()
- ADD_PROPERTY(Length,(100.0));
- ADD_PROPERTY(Reversed,(0));
- ADD_PROPERTY(MirroredExtent,(0));
-short Pad::mustExecute() const
- if (Placement.isTouched() ||
- Sketch.isTouched() ||
- Length.isTouched() ||
- MirroredExtent.isTouched() ||
- Reversed.isTouched())
- return 1;
- return 0;
-App::DocumentObjectExecReturn *Pad::execute(void)
- double L = Length.getValue();
- if (L < Precision::Confusion())
- return new App::DocumentObjectExecReturn("Length of pad too small");
- App::DocumentObject* link = Sketch.getValue();
- if (!link)
- return new App::DocumentObjectExecReturn("No sketch linked");
- if (!link->getTypeId().isDerivedFrom(Part::Part2DObject::getClassTypeId()))
- return new App::DocumentObjectExecReturn("Linked object is not a Sketch or Part2DObject");
- TopoDS_Shape shape = static_cast<Part::Part2DObject*>(link)->Shape.getShape()._Shape;
- if (shape.IsNull())
- return new App::DocumentObjectExecReturn("Linked shape object is empty");
- // this is a workaround for an obscure OCC bug which leads to empty tessellations
- // for some faces. Making an explicit copy of the linked shape seems to fix it.
- // The error almost happens when re-computing the shape but sometimes also for the
- // first time
- BRepBuilderAPI_Copy copy(shape);
- shape = copy.Shape();
- TopExp_Explorer ex;
- std::vector<TopoDS_Wire> wires;
- for (ex.Init(shape, TopAbs_WIRE); ex.More(); ex.Next()) {
- wires.push_back(TopoDS::Wire(ex.Current()));
- if (/*shape.ShapeType() != TopAbs_WIRE*/wires.empty()) // there can be several wires
- return new App::DocumentObjectExecReturn("Linked shape object is not a wire");
- // get the Sketch plane
- Base::Placement SketchPos = static_cast<Part::Part2DObject*>(link)->Placement.getValue();
- Base::Rotation SketchOrientation = SketchPos.getRotation();
- Base::Vector3d SketchOrientationVector(0,0,1);
- if (Reversed.getValue()) // negative direction
- SketchOrientationVector *= -1;
- SketchOrientation.multVec(SketchOrientationVector,SketchOrientationVector);
- // get the support of the Sketch if any
- App::DocumentObject* SupportLink = static_cast<Part::Part2DObject*>(link)->Support.getValue();
- Part::Feature *SupportObject = 0;
- if (SupportLink && SupportLink->getTypeId().isDerivedFrom(Part::Feature::getClassTypeId()))
- SupportObject = static_cast<Part::Feature*>(SupportLink);
- TopoDS_Shape aFace = makeFace(wires);
- if (aFace.IsNull())
- return new App::DocumentObjectExecReturn("Creating a face from sketch failed");
- // lengthen the vector
- SketchOrientationVector *= L;
- this->positionBySketch();
- TopLoc_Location invObjLoc = this->getLocation().Inverted();
- try {
- // extrude the face to a solid
- gp_Vec vec(SketchOrientationVector.x,SketchOrientationVector.y,SketchOrientationVector.z);
- vec.Transform(invObjLoc.Transformation());
- BRepPrimAPI_MakePrism PrismMaker(aFace.Moved(invObjLoc),vec,0,1);
- if (PrismMaker.IsDone()) {
- // if the sketch has a support fuse them to get one result object (PAD!)
- if (SupportObject) {
- // At this point the prism can be a compound
- TopoDS_Shape result = PrismMaker.Shape();
- // set the additive shape property for later usage in e.g. pattern
- this->AddShape.setValue(result);
- const TopoDS_Shape& support = SupportObject->Shape.getValue();
- bool isSolid = false;
- if (!support.IsNull()) {
- TopExp_Explorer xp;
- xp.Init(support,TopAbs_SOLID);
- for (;xp.More(); xp.Next()) {
- isSolid = true;
- break;
- if (isSolid) {
- // Let's call algorithm computing a fuse operation:
- BRepAlgoAPI_Fuse mkFuse(support.Moved(invObjLoc), result);
- // Let's check if the fusion has been successful
- if (!mkFuse.IsDone())
- return new App::DocumentObjectExecReturn("Fusion with support failed");
- result = mkFuse.Shape();
- // we have to get the solids (fuse create seldomly compounds)
- TopoDS_Shape solRes = this->getSolid(result);
- // lets check if the result is a solid
- if (solRes.IsNull())
- return new App::DocumentObjectExecReturn("Resulting shape is not a solid");
- this->Shape.setValue(solRes);
- else
- return new App::DocumentObjectExecReturn("Support is not a solid");
- else {
- TopoDS_Shape result = this->getSolid(PrismMaker.Shape());
- this->Shape.setValue(result);
+ * Copyright (c) 2010 Juergen Riegel <FreeCAD@juergen-riegel.net> *
+ * This file is part of the FreeCAD CAx development system. *
+ * This library is free software; you can redistribute it and/or *
+ * modify it under the terms of the GNU Library General Public *
+ * License as published by the Free Software Foundation; either *
+ * version 2 of the License, or (at your option) any later version. *
+ * This library is distributed in the hope that it will be useful, *
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of *
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
+ * GNU Library General Public License for more details. *
+ * You should have received a copy of the GNU Library General Public *
+ * License along with this library; see the file COPYING.LIB. If not, *
+ * write to the Free Software Foundation, Inc., 59 Temple Place, *
+ * Suite 330, Boston, MA 02111-1307, USA *
+#include "PreCompiled.h"
+#ifndef _PreComp_
+//# include <Bnd_Box.hxx>
+//# include <gp_Pln.hxx>
+# include <cmath>
+# include <BRep_Builder.hxx>
+# include <BRepBndLib.hxx>
+# include <BRepPrimAPI_MakePrism.hxx>
+# include <BRepBuilderAPI_Copy.hxx>
+# include <BRepBuilderAPI_MakeFace.hxx>
+# include <BRepOffsetAPI_MakeOffset.hxx>
+# include <BRepBuilderAPI_Transform.hxx>
+# include <BRepOffsetAPI_ThruSections.hxx>
+//# include <Geom_Plane.hxx>
+# include <Handle_Geom_Surface.hxx>
+# include <ShapeAnalysis.hxx>
+# include <TopoDS.hxx>
+# include <TopoDS_Solid.hxx>
+# include <TopoDS_Face.hxx>
+# include <TopoDS_Wire.hxx>
+# include <TopExp_Explorer.hxx>
+# include <BRepAlgoAPI_Fuse.hxx>
+# include <Precision.hxx>
+#endif
+#include <Base/Placement.h>
+#include <Base/Tools.h>
+#include <Mod/Part/App/Part2DObject.h>
+#include "FeaturePad.h"
+using namespace PartDesign;
+PROPERTY_SOURCE(PartDesign::Pad, PartDesign::Additive)
+Pad::Pad()
+ ADD_PROPERTY(Length,(100.0));
+ ADD_PROPERTY(Reversed,(0));
+ ADD_PROPERTY(MirroredExtent,(0));
+ ADD_PROPERTY(TaperAngle,(0.0f));
+short Pad::mustExecute() const
+ if (Placement.isTouched() ||
+ Sketch.isTouched() ||
+ Length.isTouched() ||
+ MirroredExtent.isTouched() ||
+ Reversed.isTouched()||
+ TaperAngle.isTouched())
+ return 1;
+ return 0;
+App::DocumentObjectExecReturn *Pad::execute(void)
+ double L = Length.getValue();
+ if (L < Precision::Confusion())
+ return new App::DocumentObjectExecReturn("Length of pad too small");
+ App::DocumentObject* link = Sketch.getValue();
+ if (!link)
+ return new App::DocumentObjectExecReturn("No sketch linked");
+ if (!link->getTypeId().isDerivedFrom(Part::Part2DObject::getClassTypeId()))
+ return new App::DocumentObjectExecReturn("Linked object is not a Sketch or Part2DObject");
+ TopoDS_Shape shape = static_cast<Part::Part2DObject*>(link)->Shape.getShape()._Shape;
+ if (shape.IsNull())
+ return new App::DocumentObjectExecReturn("Linked shape object is empty");
+ // this is a workaround for an obscure OCC bug which leads to empty tessellations
+ // for some faces. Making an explicit copy of the linked shape seems to fix it.
+ // The error almost happens when re-computing the shape but sometimes also for the
+ // first time
+ BRepBuilderAPI_Copy copy(shape);
+ shape = copy.Shape();
+ TopExp_Explorer ex;
+ std::vector<TopoDS_Wire> wires;
+ for (ex.Init(shape, TopAbs_WIRE); ex.More(); ex.Next()) {
+ wires.push_back(TopoDS::Wire(ex.Current()));
+ if (/*shape.ShapeType() != TopAbs_WIRE*/wires.empty()) // there can be several wires
+ return new App::DocumentObjectExecReturn("Linked shape object is not a wire");
+ // get the Sketch plane
+ Base::Placement SketchPos = static_cast<Part::Part2DObject*>(link)->Placement.getValue();
+ Base::Rotation SketchOrientation = SketchPos.getRotation();
+ Base::Vector3d SketchOrientationVector(0,0,1);
+ if (Reversed.getValue()) // negative direction
+ SketchOrientationVector *= -1;
+ SketchOrientation.multVec(SketchOrientationVector,SketchOrientationVector);
+ // get the support of the Sketch if any
+ App::DocumentObject* SupportLink = static_cast<Part::Part2DObject*>(link)->Support.getValue();
+ Part::Feature *SupportObject = 0;
+ if (SupportLink && SupportLink->getTypeId().isDerivedFrom(Part::Feature::getClassTypeId()))
+ SupportObject = static_cast<Part::Feature*>(SupportLink);
+ TopoDS_Shape aFace = makeFace(wires);
+ if (aFace.IsNull())
+ return new App::DocumentObjectExecReturn("Creating a face from sketch failed");
+ // lengthen the vector
+ SketchOrientationVector *= L;
+ this->positionBySketch();
+ TopLoc_Location invObjLoc = this->getLocation().Inverted();
+ gp_Vec vec(SketchOrientationVector.x,SketchOrientationVector.y,SketchOrientationVector.z);
+ vec.Transform(invObjLoc.Transformation());
+ float taperAngle = TaperAngle.getValue();
+ TopoDS_Shape result;
+ try {
+ if (std::fabs(taperAngle) >= Precision::Confusion()) {
+ //get outer Wire
+ TopoDS_Wire outerWire = ShapeAnalysis::OuterWire(TopoDS::Face(aFace));
+ double distance = std::tan(Base::toRadians(taperAngle)) * vec.Magnitude();
+ std::list<TopoDS_Wire> wire_list;
+ wire_list.push_back(outerWire);
+ BRepOffsetAPI_MakeOffset mkOffset;
+ mkOffset.AddWire(outerWire);
+ mkOffset.Perform(distance);
+ gp_Trsf mat;
+ mat.SetTranslation(vec);
+ BRepBuilderAPI_Transform mkTransform(mkOffset.Shape(),mat);
+ wire_list.push_back(TopoDS::Wire(mkTransform.Shape()));
+ BRepOffsetAPI_ThruSections mkGenerator(Standard_True);
+ for (std::list<TopoDS_Wire>::const_iterator it = wire_list.begin(); it != wire_list.end(); ++it) {
+ const TopoDS_Wire &wire = *it;
+ mkGenerator.AddWire(wire);
- else
- return new App::DocumentObjectExecReturn("Could not extrude the sketch!");
- return App::DocumentObject::StdReturn;
- catch (Standard_Failure) {
- Handle_Standard_Failure e = Standard_Failure::Caught();
- return new App::DocumentObjectExecReturn(e->GetMessageString());
+ mkGenerator.Build();
+ result = mkGenerator.Shape();
+ //no taperAngle same as before
+ else{
+ // extrude the face to a solid
+ BRepPrimAPI_MakePrism PrismMaker(aFace.Moved(invObjLoc),vec,0,1);
+ if (PrismMaker.IsDone()) {
+ result = PrismMaker.Shape();
+ else
+ return new App::DocumentObjectExecReturn("Could not extrude the sketch!");
+ // if the sketch has a support fuse them to get one result object (PAD!)
+ if (SupportObject) {
+ // set the additive shape property for later usage in e.g. pattern
+ this->AddShape.setValue(result);
+ const TopoDS_Shape& support = SupportObject->Shape.getValue();
+ bool isSolid = false;
+ if (!support.IsNull()) {
+ TopExp_Explorer xp;
+ xp.Init(support,TopAbs_SOLID);
+ for (;xp.More(); xp.Next()) {
+ isSolid = true;
+ break;
+ if (isSolid) {
+ // Let's call algorithm computing a fuse operation:
+ BRepAlgoAPI_Fuse mkFuse(support.Moved(invObjLoc), result);
+ // Let's check if the fusion has been successful
+ if (!mkFuse.IsDone())
+ return new App::DocumentObjectExecReturn("Fusion with support failed");
+ result = mkFuse.Shape();
+ // we have to get the solids (fuse create seldomly compounds)
+ TopoDS_Shape solRes = this->getSolid(result);
+ // lets check if the result is a solid
+ if (solRes.IsNull())
+ return new App::DocumentObjectExecReturn("Resulting shape is not a solid");
+ this->Shape.setValue(solRes);
+ else
+ return new App::DocumentObjectExecReturn("Support is not a solid");
+ else {
+ this->Shape.setValue(result);
+ return App::DocumentObject::StdReturn;
+ catch (Standard_Failure) {
+ Handle_Standard_Failure e = Standard_Failure::Caught();
+ return new App::DocumentObjectExecReturn(e->GetMessageString());
diff --git a/src/Mod/PartDesign/App/FeaturePad.h b/src/Mod/PartDesign/App/FeaturePad.h
index c758c94..dfaa1f6 100644
--- a/src/Mod/PartDesign/App/FeaturePad.h
+++ b/src/Mod/PartDesign/App/FeaturePad.h
@@ -42,6 +42,7 @@ public:
//App::PropertyEnumeration Side;
App::PropertyBool Reversed;
App::PropertyBool MirroredExtent;
+ App::PropertyAngle TaperAngle;
/** @name methods override feature */
diff --git a/src/Mod/PartDesign/Gui/TaskPadParameters.cpp b/src/Mod/PartDesign/Gui/TaskPadParameters.cpp
index 8a902b2..71f23e6 100644
--- a/src/Mod/PartDesign/Gui/TaskPadParameters.cpp
+++ b/src/Mod/PartDesign/Gui/TaskPadParameters.cpp
@@ -62,14 +62,17 @@ TaskPadParameters::TaskPadParameters(ViewProviderPad *PadView,QWidget *parent)
connect(ui->checkBoxMirrored, SIGNAL(toggled(bool)),
this, SLOT(onMirrored(bool)));
connect(ui->checkBoxReversed, SIGNAL(toggled(bool)),
- this, SLOT(onReversed(bool)));
+ this, SLOT(onReversed(bool)));
+ connect(ui->taperAngle, SIGNAL(valueChanged(double)),
+ this, SLOT(onTaperAngleChanged(double)));
this->groupLayout()->addWidget(proxy);
PartDesign::Pad* pcPad = static_cast<PartDesign::Pad*>(PadView->getObject());
double l = pcPad->Length.getValue();
bool mirrored = pcPad->MirroredExtent.getValue();
- bool reversed = pcPad->Reversed.getValue();
+ bool reversed = pcPad->Reversed.getValue();
+ double ta = pcPad->TaperAngle.getValue();
ui->doubleSpinBox->setMinimum(0);
ui->doubleSpinBox->setValue(l);
@@ -77,11 +80,13 @@ TaskPadParameters::TaskPadParameters(ViewProviderPad *PadView,QWidget *parent)
ui->checkBoxMirrored->setChecked(mirrored);
// According to bug #0000521 the reversed option
// shouldn't be de-activated if the pad has a support face
- ui->checkBoxReversed->setChecked(reversed);
+ ui->checkBoxReversed->setChecked(reversed);
+ ui->taperAngle->setValue(ta);
// Make sure that the spin box has the focus to get key events
// Calling setFocus() directly doesn't work because the spin box is not
- // yet visible.
+ // yet visible.
QMetaObject::invokeMethod(ui->doubleSpinBox, "setFocus", Qt::QueuedConnection);
@@ -104,6 +109,13 @@ void TaskPadParameters::onReversed(bool on)
pcPad->Reversed.setValue(on);
pcPad->getDocument()->recomputeFeature(pcPad);
+void TaskPadParameters::onTaperAngleChanged(double ta)
+ PartDesign::Pad* pcPad = static_cast<PartDesign::Pad*>(PadView->getObject());
+ pcPad->TaperAngle.setValue(static_cast<float>(ta));
+ pcPad->getDocument()->recomputeFeature(pcPad);
double TaskPadParameters::getLength(void) const
@@ -119,6 +131,12 @@ bool TaskPadParameters::getReversed(void) const
bool TaskPadParameters::getMirroredExtent(void) const
return ui->checkBoxMirrored->isChecked();
+float TaskPadParameters::getTaperAngle(void) const
+ float t = static_cast<float>(ui->taperAngle->value());
+ return static_cast<float>(ui->taperAngle->value());
TaskPadParameters::~TaskPadParameters()
@@ -158,12 +176,12 @@ TaskDlgPadParameters::~TaskDlgPadParameters()
void TaskDlgPadParameters::open()
void TaskDlgPadParameters::clicked(int)
bool TaskDlgPadParameters::accept()
@@ -174,7 +192,8 @@ bool TaskDlgPadParameters::accept()
//Gui::Command::openCommand("Pad changed");
Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.%s.Length = %f",name.c_str(),parameter->getLength());
Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.%s.Reversed = %i",name.c_str(),parameter->getReversed()?1:0);
- Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.%s.MirroredExtent = %i",name.c_str(),parameter->getMirroredExtent()?1:0);
+ Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.%s.MirroredExtent = %i",name.c_str(),parameter->getMirroredExtent()?1:0);
+ Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.%s.TaperAngle = %f",name.c_str(),parameter->getTaperAngle());
Gui::Command::doCommand(Gui::Command::Doc,"App.ActiveDocument.recompute()");
if (!PadView->getObject()->isValid())
throw Base::Exception(PadView->getObject()->getStatusString());
@@ -192,18 +211,18 @@ bool TaskDlgPadParameters::accept()
bool TaskDlgPadParameters::reject()
// get the support and Sketch
- PartDesign::Pad* pcPad = static_cast<PartDesign::Pad*>(PadView->getObject());
Sketcher::SketchObject *pcSketch;
App::DocumentObject *pcSupport;
if (pcPad->Sketch.getValue()) {
- pcSketch = static_cast<Sketcher::SketchObject*>(pcPad->Sketch.getValue());
+ pcSketch = static_cast<Sketcher::SketchObject*>(pcPad->Sketch.getValue());
pcSupport = pcSketch->Support.getValue();
// role back the done things
Gui::Command::abortCommand();
Gui::Command::doCommand(Gui::Command::Gui,"Gui.activeDocument().resetEdit()");
// if abort command deleted the object the support is visible again
if (!Gui::Application::Instance->getViewProvider(pcPad)) {
if (pcSketch && Gui::Application::Instance->getViewProvider(pcSketch))
diff --git a/src/Mod/PartDesign/Gui/TaskPadParameters.h b/src/Mod/PartDesign/Gui/TaskPadParameters.h
index c16493c..d3f4a87 100644
--- a/src/Mod/PartDesign/Gui/TaskPadParameters.h
+++ b/src/Mod/PartDesign/Gui/TaskPadParameters.h
@@ -40,7 +40,7 @@ namespace Gui {
class ViewProvider;
-namespace PartDesignGui {
+namespace PartDesignGui {
@@ -54,12 +54,14 @@ public:
double getLength(void) const;
bool getReversed(void) const;
- bool getMirroredExtent(void) const;
+ bool getMirroredExtent(void) const;
+ float getTaperAngle(void) const;
private Q_SLOTS:
void onLengthChanged(double);
void onMirrored(bool);
- void onReversed(bool);
+ void onReversed(bool);
+ void onTaperAngleChanged(double);
protected:
void changeEvent(QEvent *e);
@@ -94,11 +96,11 @@ public:
virtual bool accept();
/// is called by the framework if the dialog is rejected (Cancel)
virtual bool reject();
- /// is called by the framework if the user presses the help button
+ /// is called by the framework if the user presses the help button
virtual bool isAllowedAlterDocument(void) const
{ return false; }
- /// returns for Close and Help button
+ /// returns for Close and Help button
virtual QDialogButtonBox::StandardButtons getStandardButtons(void) const
{ return QDialogButtonBox::Ok|QDialogButtonBox::Cancel; }
diff --git a/src/Mod/PartDesign/Gui/TaskPadParameters.ui b/src/Mod/PartDesign/Gui/TaskPadParameters.ui
index d407bbf..5048e66 100644
--- a/src/Mod/PartDesign/Gui/TaskPadParameters.ui
+++ b/src/Mod/PartDesign/Gui/TaskPadParameters.ui
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>158</width>
- <height>116</height>
+ <width>206</width>
+ <height>138</height>
</rect>
</property>
<property name="windowTitle">
@@ -62,6 +62,30 @@
</layout>
</item>
<item>
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="label_2">
+ <property name="text">
+ <string>Taper Angle:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="taperAngle">
+ <property name="minimum">
+ <double>-180.000000000000000</double>
+ </property>
+ <property name="maximum">
+ <double>180.000000000000000</double>
+ </property>
+ <property name="singleStep">
+ <double>5.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
<widget class="QCheckBox" name="checkBoxMirrored">
<property name="enabled">
<bool>false</bool>
@@ -80,6 +104,13 @@
</item>
</layout>
</widget>
+ <tabstops>
+ <tabstop>changeMode</tabstop>
+ <tabstop>doubleSpinBox</tabstop>
+ <tabstop>taperAngle</tabstop>
+ <tabstop>checkBoxMirrored</tabstop>
+ <tabstop>checkBoxReversed</tabstop>
+ </tabstops>
<resources/>
<connections/>
</ui>
1.7.9.5
From b5761db235d803e5d0020ea2c7fc15747759b148 Mon Sep 17 00:00:00 2001
Date: Sun, 29 Apr 2012 09:52:17 +0200
Subject: [PATCH 2/2] removes TabStop changes
src/Mod/PartDesign/Gui/TaskPadParameters.ui | 7 -------
1 file changed, 7 deletions(-)
index 5048e66..5623a40 100644
@@ -104,13 +104,6 @@
</item>
</layout>
</widget>
- <tabstops>
- <tabstop>changeMode</tabstop>
- <tabstop>doubleSpinBox</tabstop>
- <tabstop>taperAngle</tabstop>
- <tabstop>checkBoxMirrored</tabstop>
- <tabstop>checkBoxReversed</tabstop>
- </tabstops>
<resources/>
<connections/>
</ui>
1.7.9.5
Patch applied to Assembly branch! Works well! To be done -> Use code in Pocket |
in progress |
V0.13 now has a PartDesign::Draft feature which allows to select faces and apply a draft angle to them. This is not the same functionality as that requested, but will lead to the same result. I am not sure whether we should put even more options into the Pad/Pocket features. When I modelled for customers from the German automative industry, they insisted on always having draft in a separate feature. |
Draft can be done Pocket/Pad for easy and simple cases. If you want to have more control Pad/Pocket get for sure overloaded. I think both make sense. A one angle solution in the basic features and a own feature for the more sophisticated (future) solutions.. I have generally no problem if there are overlapping features functionality. May the better win! |
This ticket has been migrated to GitHub as issue 5553. |
| 2012-03-05 21:17 | electronlibre | New Issue | |
| 2012-03-09 06:07 |
Status | new => assigned |
| 2012-03-09 06:07 |
Assigned To | => Jriegel |
| 2012-04-29 05:53 | helo10 | File Added: TaperAngle_Pad.patch | |
| 2012-05-05 18:00 | yorik | Project | FreeCAD => PartDesign |
| 2012-05-18 10:38 |
Note Added: 0002058 | |
| 2012-06-08 11:26 | helo10 | Note Added: 0002156 | |
| 2013-01-13 14:32 | jrheinlaender | Note Added: 0002845 | |
| 2013-01-13 14:39 |
Note Added: 0002846 | |
| 2017-05-31 00:23 | Kunda1 | Assigned To | Jriegel => |
| 2017-05-31 00:23 | Kunda1 | Status | assigned => confirmed |
