| 0000634 | Draft | Bug | public | 2012-03-12 10:19 | 2012-08-11 19:26 |
| Summary | 0000634: Draft <--> Sketch conversion | ||||
| Description | Hi, I have attached a file. It has one Face. You can explode this face to wires. Once you do, You can convert all those wires to sketches, but issues appear: 1 - sketch is moved to XY plane - does not keep correct plane 2 - arcs import badly | ||||
| Additional Information | 0.13 unstable (0699) on win7 64 bit. | ||||
2012-03-12 10:53
ok, I'll have a look |
Just wanted to note that sometimes sketch looks good, but if you open it (double click on it) it starts looking bad. But when it is closed, it looks good. Regards Petar |
Okay indeed the arcs are wrong... But the sketch orientation seems OK to me (I tried rotating the face before exploding). I'm looking at the arcs issue now |
hm this is really hard to solve, the sketcher has a lot of problems when you add geoms that have different orientations than the base sketch |
Fixed in 7a338f3. As far as I tested, draft to sketch conversions now behave correctly. There is a shift in some shapes that are not on the XY plane, but I suppose this is as far as I can fix at the moment. |
| 2012-03-12 10:19 | pperisin | New Issue | |
| 2012-03-12 10:53 | pperisin | File Added: draftissue.FCStd | |
| 2012-03-12 21:31 | yorik | Status | new => assigned |
| 2012-03-12 21:31 | yorik | Assigned To | => yorik |
| 2012-03-12 21:32 | yorik | Note Added: 0001758 | |
| 2012-03-13 13:52 | pperisin | Note Added: 0001762 | |
| 2012-03-13 14:06 | yorik | Note Added: 0001763 | |
| 2012-03-13 15:12 | yorik | Note Added: 0001765 | |
| 2012-05-04 13:14 | yorik | Project | FreeCAD => Draft |
| 2012-05-23 11:31 | yorik | Relationship added | parent of 0000718 |
| 2012-08-11 19:26 | yorik | Note Added: 0002316 | |
| 2012-08-11 19:26 | yorik | Status | assigned => closed |
| 2012-08-11 19:26 | yorik | Resolution | open => fixed |
| 2012-08-11 19:26 | yorik | Fixed in Version | => 0.13 |
