| 0000718 | Draft | Bug | public | 2012-05-22 23:37 | 2012-08-11 19:27 |
| Reporter | djreichel | Assigned To | yorik | ||
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000718: Draft to Sketch conversion malfunctions | ||||
| Description | Fedora 16 32bit Version: 0.13.0978 (Git) Branch: master Hash: 84d8605b83b1f839590cb4c6c6842f7ff570219f A Draft circle created in GUI on the XZ plane, with center at around 0,5, will shift position to around 0,0 when it's converted to a sketch. Then when the sketch is opened to edit, the view rolls 90 degrees about the X axis and the circle appears as a line. In spite of the incorrect view of the sketch, a sweep made of the sketch produced a proper result. I discovered this behavior while snapping draft circles to both ends of a helix in order to test creating a variable profile swept spring. | ||||
| 2012-05-22 23:37 | djreichel | New Issue | |
| 2012-05-23 11:31 | yorik | Relationship added | child of 0000634 |
| 2012-05-23 11:32 | yorik | Note Added: 0002079 | |
| 2012-05-23 11:32 | yorik | Status | new => assigned |
| 2012-05-23 11:32 | yorik | Assigned To | => yorik |
| 2012-06-12 17:02 | yorik | Project | FreeCAD => Draft |
| 2012-06-12 17:06 | yorik | Target Version | => 0.13 |
| 2012-08-11 19:27 | yorik | Note Added: 0002317 | |
| 2012-08-11 19:27 | yorik | Status | assigned => closed |
| 2012-08-11 19:27 | yorik | Resolution | open => fixed |
| 2012-08-11 19:27 | yorik | Fixed in Version | => 0.13 |
