| 0000642 | Draft | Bug | public | 2012-03-15 13:59 | 2012-08-17 18:45 |
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000642: Bugs in DraftSnap | ||||
| Description | 1) Draft menu doesn't have an ALT shortcut 2) Draft->Show draft toolbar menu pops the toolbar out of the freecad window 3) The snap toolbar has no objecTName/windowTitle when opened outside of the Draft WB 4) Feature - Add an option to close the snap toolbar after the tool closes | ||||
5) Add an icon for "nearest" 6) Remove use of shift key, think about ctrl key behaviour 7) Solve snap distance problems |
2) and 5) are done |
8) add perpendicular X extension snap |
1) and 4) are fixed too |
Even if 'show draft snap toolbar' is checked in preferences, it doesn't appear until you attempt to draw something. I think if selection is made, the toolbar should always be visible. It would be nice if it remembered which snap tools were selected between sessions. Snapping to 'everything' as a default is a bit irritating. |
Good idea, I'll try to set that up too |
Draft snap states are now remembered across sessions. For displaying the bar immediately, unfortunately there si the same problem as the grid, and at the moment I have no solution for it. |
9) Grid and plane widgets conflict with snapping, preventing from selecting the underlying objects |
9) is solved. Still to do: 3, 6, 7, 8 |
7) is solved Still to do: 3) The snap toolbar has no objecTName/windowTitle when opened outside of the Draft WB 6) Remove use of shift key, think about ctrl key behaviour 8) add perpendicular X extension snap |
8) is done |
6) is now done with 0000715. Shift-constraining is still available, but will probably be disabled in the future. Still to do: 3) The snap toolbar has no objecTName/windowTitle when opened outside of the Draft WB |
Will close now since all is basically working, no solution found for the toolbar naming problem, but I might change it all to proper FreeCAD Commands later... |
| 2012-03-15 13:59 | yorik | New Issue | |
| 2012-03-15 13:59 | yorik | Status | new => assigned |
| 2012-03-15 13:59 | yorik | Assigned To | => yorik |
| 2012-03-16 11:35 | yorik | Note Added: 0001781 | |
| 2012-03-16 11:36 | yorik | Note Edited: 0001781 | |
| 2012-03-19 17:21 | yorik | Note Added: 0001793 | |
| 2012-03-19 17:23 | yorik | Note Added: 0001794 | |
| 2012-03-19 17:28 | yorik | Note Added: 0001795 | |
| 2012-03-19 17:46 | yorik | Note Edited: 0001795 | |
| 2012-04-07 19:07 | sliptonic | Note Added: 0001902 | |
| 2012-04-07 20:38 | yorik | Note Added: 0001904 | |
| 2012-04-08 13:48 | yorik | Note Added: 0001909 | |
| 2012-05-04 13:14 | yorik | Project | FreeCAD => Draft |
| 2012-06-06 15:18 | yorik | Note Added: 0002140 | |
| 2012-06-07 12:19 | yorik | Note Added: 0002144 | |
| 2012-06-09 13:39 | yorik | Note Added: 0002168 | |
| 2012-06-09 16:58 | yorik | Note Added: 0002169 | |
| 2012-06-11 15:35 | yorik | Note Added: 0002180 | |
| 2012-08-17 18:45 | yorik | Note Added: 0002323 | |
| 2012-08-17 18:45 | yorik | Status | assigned => closed |
| 2012-08-17 18:45 | yorik | Resolution | open => fixed |
| 2012-08-17 18:45 | yorik | Fixed in Version | => 0.13 |
