| 0000679 | Draft | Bug | public | 2012-04-23 08:22 | 2012-08-11 19:29 |
| Reporter | benjamin12345 | Assigned To | yorik | ||
| Summary | 0000679: Arcs get wrong orientation when exporting to dxf | ||||
| Description | When arcs are drawn within a sketch and the sketch is exported as dxf the arcs sometimes get the wrong orientation in the resulting dxf file. This does not always happen, but in about 50% of the cases. An example document with this problem and the resulting dxf file is attached to this bug report. This has been a problem ever since I started using FreeCad, which was sometime about version 0.12. | ||||
| Additional Information | Freecad version: Version: 0.13.0784 (Git) Branch: master Hash: 2e062ab79713607566248a1e480b8921d5a03b58 | ||||
| 2012-04-23 08:22 | benjamin12345 | New Issue | |
| 2012-04-23 08:22 | benjamin12345 | File Added: Arc_test.zip | |
| 2012-04-23 17:34 | yorik | Note Added: 0001964 | |
| 2012-04-23 17:34 | yorik | Status | new => assigned |
| 2012-04-23 17:34 | yorik | Assigned To | => yorik |
| 2012-05-04 13:14 | yorik | Project | FreeCAD => Draft |
| 2012-08-11 19:29 | yorik | Note Added: 0002318 | |
| 2012-08-11 19:29 | yorik | Status | assigned => closed |
| 2012-08-11 19:29 | yorik | Resolution | open => fixed |
| 2012-08-11 19:29 | yorik | Fixed in Version | => 0.13 |
