| 0000768 | PartDesign | Bug | public | 2012-07-01 05:04 | 2017-03-27 08:30 |
| Reporter | jmaustpc | Assigned To | wmayer | ||
| Platform | 64 bit | OS | kubuntu | OS Version | 12.04 |
| Summary | 0000768: Part Sweep and Loft limitations and bugs | ||||
| Description | Part loft and sweep either not working at all or producing only a surface is many situations. | ||||
| Steps To Reproduce | I wanted to make a dinning room chair back. So I tried 5 different approaches, the first worked but with a face rendered past the end on the ellipse and only the last worked perfectly. 1) I tried to loft from one Part ellipse to another and could only get a surface even with "make solid" ticked 2) as described here https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=10&t=2762 I created a top and bottom ellipse from Part create primitives, then used Part Shape Builder to create a Part Face from the ellipse. The face was longer than the ellipse (a bug), still I lofted (but only got a surface surface) between the two ellipses, then got the two faces from ellipses and the loft surface, then added them together to make a shell in Part Shape Builder, then used Part Shape Builder again to make the shell into a solid. This did work except that the top and bottom ellipses did render to long in the x direction. 3) I made a top sketch and a bottom sketch. Loft between sketches also only made a surface despite having ticked "make solid" 4) then I created a sketch for a path and used Part Sweep with the two ellipses and the sketch for Path, it worked except that is would not make a solid even though "make solid" was ticked, so I only got a surface again. 5) this finally worked, I created a sketch for the top and another for the bottom, then another sketch for the path, I then used Part Sweep from one sketch to the other using the third as the Path and ticked "make solid" which produced a solid. :) | ||||
| Additional Information | Platform: Ubuntu 12.04 LTS (64-bit) Version: 0.13.1212 (Git) Branch: master Hash: dfca264acfa6fc7c58d4ca695c5ac76507568073 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
2012-07-01 05:04
here is a link to the appropriate forum topic http://forum.freecadweb.org/viewtopic.php?f=10&t=2763 |
Its again the limitations of OCC. |
git show 5a96582 fixes "loft_chair_back_from_sketches". So, only the loft and sweep using the ellipses don't create the expected solid. |
The loft and sweep doesn't work because the ellipses are not complete. The start angle for all of them is 1 deg so that are not closed and thus a solid cannot be created. After setting the correct start angle everything works perfectly. |
| 2012-07-01 05:04 | jmaustpc | New Issue | |
| 2012-07-01 05:04 | jmaustpc | File Added: dinning_room_chair_render_sweep_loft_problems_examples.FCStd | |
| 2012-07-01 05:07 | jmaustpc | Note Added: 0002252 | |
| 2012-07-01 12:51 | yorik | Project | FreeCAD => PartDesign |
| 2012-12-20 20:41 |
Note Added: 0002708 | |
| 2012-12-20 20:41 |
Status | new => confirmed |
| 2013-10-13 07:14 | wmayer | Note Added: 0003741 | |
| 2013-10-13 07:42 | wmayer | Note Added: 0003742 | |
| 2013-10-13 07:42 | wmayer | Status | confirmed => assigned |
| 2013-10-13 07:42 | wmayer | Assigned To | => wmayer |
| 2013-10-13 07:43 | wmayer | Status | assigned => closed |
| 2013-10-13 07:43 | wmayer | Resolution | open => fixed |
| 2013-10-13 07:43 | wmayer | Fixed in Version | => 0.14 |
| 2017-03-27 08:30 | Kunda1 | Changeset attached | => FreeCAD master 5a96582a |
