| 0000794 | PartDesign | Bug | public | 2012-07-15 16:51 | 2021-02-20 13:46 |
| Reporter | tuxontour | Assigned To | |||
| Summary | 0000794: External reference in sketch changes | ||||
| Description | Hi with the current GIT version 0.13R1260 (kubuntu 12.04, 64bit) the external references change under certain circumstances. See the attached geometry file. How to reproduce it. - Load it and remember where the big holes in the baseplate are located - Make "Pocket003" invisible - Edit "Pocket001->Sketch004" - Change the length contraint from 28mm to 35mm - Leave and make "Pocket003" visible again - Note how the big holes have moved - The external reference in "Pocket002->Sketch005" has changed and it shouldn't have changed Thanks Matthias | ||||
| Tags | toponaming | ||||
| duplicate of | 0000922 | assigned | realthunder | FreeCAD | Topological Naming |
2012-07-15 16:51
Also happens after performing Part Design-> Migrate with 0.17, but if everything is corrected, changing the dimension from 29->30 has no effect. Version details: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10540 (Git) Build type: None Branch: master Hash: 2c9d5e30108a2a34a7f11cfad3d9c323e5577ce1 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
@kunda1 Toponaming project Probably downgrading severity for these reasons: 1. We known about toponaming, until it is handled there is nothing to do to this ticket. We shall survive until then. 2. We need to have a clear picture of what is important to fix in PD NEXT. These tickets are noise for that goal. |
@Abdullah thanks for the feedback. Feel free to up/downgrade any tickets you come by that you deem fit. |
This is toponaming bug and is one of many dupes. Closing in favor of 0000922 |
| 2012-07-15 16:51 | tuxontour | New Issue | |
| 2012-07-15 16:51 | tuxontour | File Added: Gelenk.FCStd | |
| 2012-08-06 18:52 | logari81 | Status | new => assigned |
| 2012-08-06 18:52 | logari81 | Assigned To | => logari81 |
| 2012-12-20 20:40 | logari81 | Relationship added | child of 0000922 |
| 2017-03-23 06:36 | jnxd | Note Added: 0008690 | |
| 2017-03-23 06:38 | jnxd | Note Edited: 0008690 | |
| 2017-04-02 08:53 | kkremitzki | Assigned To | logari81 => |
| 2017-04-02 08:54 | kkremitzki | Status | assigned => new |
| 2017-05-02 21:20 | Kunda1 | Status | new => confirmed |
| 2017-05-24 21:45 | abdullah | Note Added: 0009113 | |
| 2017-05-24 21:48 | Kunda1 | Note Added: 0009114 | |
| 2017-05-24 21:49 | Kunda1 | Severity | major => minor |
| 2017-05-24 21:49 | Kunda1 | Assigned To | => jnxd |
| 2017-05-24 21:49 | Kunda1 | Status | confirmed => assigned |
| 2021-02-20 13:46 | Kunda1 | Assigned To | jnxd => |
| 2021-02-20 13:46 | Kunda1 | Status | assigned => closed |
| 2021-02-20 13:46 | Kunda1 | Resolution | open => duplicate |
| 2021-02-20 13:46 | Kunda1 | Note Added: 0015377 | |
| 2021-02-20 13:46 | Kunda1 | Relationship replaced | duplicate of 0000922 |
| 2021-02-20 13:46 | Kunda1 | Tag Attached: toponaming |
