| 0000850 | FreeCAD | Feature | public | 2012-09-28 02:26 | 2021-02-06 06:50 |
| Reporter | jrheinlaender | Assigned To | |||
| Summary | 0000850: Write own and better version of BRepFeat_MakePrism | ||||
| Description | This will resolve the following problems: 1. BRepFeat_MakePrism does not always give correct results when the UpToFace is not planar (and sometimes it even makes a difference whether the UpToFace is convex or concave!!!) 2. BRepFeat_MakePrism with option "2" cannot generate a correct SubShape for Pocket/UpToFirst because the subtracted material is completely inside the support - so there is no added material 3. And if we define AddShape and SubShape as reflecting not the added/subtracted material but the design intent (see separate thread I started) then we also will not be able to use BRepFeat_MakePrism any more and will fix the following bugs: 0000775 0000766 | ||||
| Additional Information | Planned for 0.14 | ||||
| related to | 0001655 | closed | wmayer | PartDesign | Pocket type UpToFirst and UpToFace doesn't produce expected results. |
| parent of | 0000775 | closed | logari81 | FreeCAD | Part/Pocket fails up to curved face if that face is smaller than the sketch |
| parent of | 0000766 | closed | PartDesign | Pad and Pocket fail to extrude up to a face if that is smaller than the sketch being extruded | |
| parent of | 0000758 | closed | FreeCAD | Pad and Pocket do not extrude properly to a curved surface |
| 2012-09-28 02:26 | jrheinlaender | New Issue | |
| 2013-01-13 14:27 | jrheinlaender | Relationship added | parent of 0000775 |
| 2013-01-13 14:27 | jrheinlaender | Relationship added | parent of 0000766 |
| 2013-01-13 14:30 | jrheinlaender | Relationship added | parent of 0000758 |
| 2015-05-15 20:15 | wmayer | Relationship added | related to 0001655 |
| 2017-03-29 18:49 | Kunda1 | Description Updated | |
| 2017-03-29 18:50 | Kunda1 | Note Added: 0008735 | |
