| 0000860 | FreeCAD | Bug | public | 2012-10-30 08:16 | 2013-12-23 17:41 |
| Reporter | jrheinlaender | Assigned To | jrheinlaender | ||
| Summary | 0000860: PartDesign/modelrefine.cpp in FaceUniter::process() : United faces should all be marked as modified | ||||
| Description | Image someone has used the second face of the two faces being united to draw a sketch on. Unfortunately, this face is marked as deleted, so the sketch loses its support. If both faces were marked as modified, then this problem would not occur. This is not a serious issue until topological naming is implemented. | ||||
| related to | 0000873 | closed | jrheinlaender | RefineModel() does not mark edges/faces as modified |
Thats quit right, but postponed till Naming is implemented. |
Implemented on http://github.com/jrheinlaender/FreeCAD/tree/jrheinlaender/dev-assembly-partdesign-modelrefine |
git show b2a341540e0482e8aaf80545f39fc08cf71f8a4d |
| 2012-10-30 08:16 | jrheinlaender | New Issue | |
| 2012-11-08 08:24 | wmayer | Relationship added | related to 0000873 |
| 2012-11-13 20:17 |
Note Added: 0002511 | |
| 2012-11-13 20:17 |
Assigned To | => Jriegel |
| 2012-11-13 20:17 |
| 2012-11-13 20:18 |
Target Version | => 0.14 |
| 2013-11-04 18:37 | jrheinlaender | Note Added: 0003853 | |
| 2013-11-04 18:38 | jrheinlaender | Assigned To | Jriegel => jrheinlaender |
| 2013-11-04 18:38 | jrheinlaender | Status | acknowledged => assigned |
| 2013-12-23 17:41 | wmayer | Note Added: 0003975 | |
| 2013-12-23 17:41 | wmayer | Status | assigned => closed |
| 2013-12-23 17:41 | wmayer | Resolution | open => fixed |
| 2013-12-23 17:41 | wmayer | Fixed in Version | => 0.14 |
