| 0000873 | FreeCAD | Bug | public | 2012-11-07 15:08 | 2013-12-23 17:41 |
| Reporter | jrheinlaender | Assigned To | jrheinlaender | ||
| Summary | 0000873: RefineModel() does not mark edges/faces as modified | ||||
| Description | See the attached picture. I tried to label four entities (from left to right): Face2 Edge7,8,9 After the ModelRefine() run, the three edges are joined into a single edge. But only Edge7 is marked as modified, Edge8 and 9 are marked neither as modified nor deleted (IMO they should be marked as modified so that later methods can deduce that these three edges were joined into one new edge). Also, Face2 should also be marked as modified because its limiting wire has changed. For example, IsSame() will not recognize old and new Face2 as equal. | ||||
| related to | 0000860 | closed | jrheinlaender | PartDesign/modelrefine.cpp in FaceUniter::process() : United faces should all be marked as modified |
| child of | 0000922 | assigned | realthunder | Topological Naming |
2012-11-07 15:08
Implemented on http://github.com/jrheinlaender/FreeCAD/tree/jrheinlaender/dev-assembly-partdesign-modelrefine [^] |
git show b2a341540e0482e8aaf80545f39fc08cf71f8a4d |
| 2012-11-07 15:08 | jrheinlaender | New Issue | |
| 2012-11-07 15:08 | jrheinlaender | File Added: Unrefined.jpg | |
| 2012-11-08 08:24 | wmayer | Relationship added | related to 0000860 |
| 2012-12-20 19:27 |
Relationship added | child of 0000922 |
| 2012-12-20 19:27 |
Status | new => assigned |
| 2012-12-20 19:27 |
Assigned To | => Jriegel |
| 2012-12-20 19:28 |
Target Version | => 0.14 |
| 2013-11-04 18:37 | jrheinlaender | Note Added: 0003852 | |
| 2013-11-04 18:37 | jrheinlaender | Assigned To | Jriegel => jrheinlaender |
| 2013-12-23 17:41 | wmayer | Note Added: 0003976 | |
| 2013-12-23 17:41 | wmayer | Status | assigned => closed |
| 2013-12-23 17:41 | wmayer | Resolution | open => fixed |
| 2013-12-23 17:41 | wmayer | Fixed in Version | => 0.14 |
