| 0000868 | Draft | Bug | public | 2012-11-02 12:43 | 2017-01-19 15:24 |
| Reporter | mzahor1 | Assigned To | |||
| Summary | 0000868: BRep_API: command not done [ MAC OSX ] | ||||
| Description | When trying to fillet some edges, message "BRep_API: command not done" and object is lost. Example attached - when trying to fillet the axe profil. MAC OS X Mountain LION, V: 0,13 | ||||
| related to | 0002110 | closed | FreeCAD | BRep_API: command not done |
2012-11-02 12:43
Can not reproduce with actuall master... |
I'm not sure the Part Fillet tool is able to fillet 2D wires, if that is what is intended here. For the 3D shapes for me too filleting works fine. To fillet 2D shapes you can turn them to Draft wires with the draft upgrade tool, then they have a "fillet" property you can use, or you can turn them into 3D shapes (make a face, then extrude), then fillet with the Part Fillet tool. |
No further feedback given and unable to reproduce on any other system. |
| 2012-11-02 12:43 | mzahor1 | New Issue | |
| 2012-11-02 12:43 | mzahor1 | File Added: axe.FCStd | |
| 2012-11-13 20:46 |
Note Added: 0002513 | |
| 2012-11-13 20:47 |
Status | new => feedback |
| 2013-02-09 14:55 | yorik | Note Added: 0002889 | |
| 2014-06-22 08:48 | wmayer | Note Added: 0004761 | |
| 2014-06-22 08:48 | wmayer | Status | feedback => closed |
| 2014-06-22 08:48 | wmayer | Resolution | open => unable to reproduce |
| 2017-01-19 15:24 | Kunda1 | Relationship added | related to 0002110 |
